Folding GPU suggestions?
Discussion in 'bit-tech Folding Team' started by Christopher N. Lew, 13 Apr 2010.
  1. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
    I'm eyeing some empty PCIe slots, thinking about the upcoming challenge. Does anyone know of a nVidia based graphics card that (a) only requires a 6-pin power connection and (b) actually exhausts the hot air out the back of the PC, not just moving it around the interior? Cheap and quiet would be nice, but not critical. :D
  2. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Hmmm thats a toughie. Most of the dual slot nVidia cards by definition need more power. The 240GT requires very little power, but exhausts heat into the case.
  3. Christopher N. Lew
    23 Apr 2009
    Can't say I've searched systematically, but some EVGA GTS 250s and XFX 240s fit the bill as far as exhaust and power go. Seems to be important to get just the right model to get the exhausting.
  4. Paddy4929
    Paddy4929 NangO-Gamer
    24 Apr 2009
    My GTS 250's only require one 6 pin connector to run and exhaust the heat out the back.
  5. Ph4ZeD
    22 Jul 2009
    250 GTS only requires one 6 pin connector? I thought they required two?
  6. littlepuppi
    littlepuppi Currently playing MWO and loving it
    26 Apr 2009
    Thye have been improved and only need 1 now......
  7. Christopher N. Lew
    23 Apr 2009
    Make and model please, and how much memory, as this seems to influence the cooler design?
  8. Synay
    Synay What's a Dremel?
    25 Oct 2009
    I just got my second GTS 250 and can't be happier. Both of them are XFX with 512MB od memory, but 1GB is not that hard to find. The one I got today is here and it only needs 1 connector, same as my older one which is clocked at 738MHz. Refardless, return is 5000-6000 PPD each.
    edit:
    I just pulled the new one to the 738MHz and core and 1836MHz shaders to mach the normal version I have no problem.
    edit 2:
    The one I pointed you to has an opened type cooler, but still, somehow blow the air backwards.
  9. Lehmann
    Lehmann What's a Dremel?
    18 Dec 2009
    Depending on your power supply. the bfg gtx 260oc come with 1 molex to pci adaptor.
