free word processing
Discussion in 'Software' started by chrisb2e9, 19 Mar 2008.
  1. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    Hello,
    Are there are free word processing programs out there similar to what Microsoft Word can do? I used to have the cd for it but I cant find it now and I was wondering if there may be an open source program or something else that is available to download without purchase.
    Thanks.
  2. Matticus
    Matticus ...
    23 Feb 2008
    Open office is your best bet
    http://www.openoffice.org/
    Quite simalar to MS office, so its easy to migrate from MS office to openoffice.
    Hope that helps
  3. Squadexodus
    Squadexodus I got my cookie. What about you?
    5 Jan 2008
    You beat me...
    But the cool thing about open office is that it can open word documents, and word can open its documents.
  4. chrisb2e9
    18 Jun 2007
    Perfect, I knew I had seen someone metion that before but I couldn't remember the name of it.
    Thanks!
  5. sam.g.taylor
    sam.g.taylor Apparently I'm Greg Kinnear
    15 Aug 2006
    OpenOffice is good (I use it meself) but since it's a little large and resource hungry, if you just want a word processing program w/out the rest of the suite try AbiWord. It's got a lot of functionality but is lot lighter on your CPU and RAM (and HD, of course) than OpenOffice.
  6. Elv13
    Elv13 What's a Dremel?
    26 Apr 2006
    KWord is comming soon for windows too, you can compile it right now, but it is not really usable for windows yet.
  7. johnmalc
    johnmalc That shouldn't happen....
    7 Jul 2007
    Never knew it was available for the Windows platform, many thanks for the heads up! A great little program with multi language capability, all for free :thumb:
  8. Yotta
    Yotta Minimodder
    10 Mar 2008
    As long as you don't save as the original default file type of odt. Easy enough to change the default file format though: tools > options > load/save > general > default file format > pick one you like. :)
    Being able to export as pdf is a nice feature of open office.
  9. DGrieve
    DGrieve What's a Dremel?
    15 Mar 2008
    Although OpenOffice is a bit slow (pretty much because it's running on the JRE) it's such a small price to pay as opposed to... well, the big price of Microsoft Office. Not to mention it's cross platform, OpenOffice 3.0 is coming out soon (I think it's in beta) and receives a lot more community support than its counter-part.
    One of the best software packages available in my opinion, and nearly all Linux distros have it installed as standard.
  10. rls669
    rls669 i can has dremel?
    15 Mar 2008
    I've heard that really elaborate documents give it fits, but it's more than enough for most users. If you're used to PowerPoint and switch to OO you might have a few :wallbash: moments though.
  11. DLoney
    DLoney What's a Dremel?
    21 Feb 2005
  12. rls669
    15 Mar 2008
    Looks interesting, thanks for posting that.
  13. mushky
    mushky gimme snails
    24 Mar 2003
    I use Openoffice mostly, but if I'm not at home or just want a quick fix I use Google Docs.
