Windows hamachi alternative
Discussion in 'Software' started by s1n1s, 25 Jan 2013.
  1. s1n1s
    s1n1s What's a Dremel?
    5 Aug 2009
    anyone know of a decent hamachi alternative (freeware)
  2. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Sort of depends on your use case. I find tunngle to be pretty good for gaming use.
  3. adam_bagpuss
    24 Apr 2009
    but hamachi is free and works a treat ?
  4. Edwards
    Edwards Minimodder
    8 Oct 2010
    If you're trying to play games via a VPN tunnel, there is also GameRanger. It only supports certain games, but is worth a try.
  5. s1n1s
    5 Aug 2009
    kl thanks yeah i've heard of tunngle, i'll check games ranger out. as for hamachi i haven't used it for a long while and not sure i like what i see with the log me in website, the fact there is also a paid version makes me thinks they've watered down the free one one.
  6. adam_bagpuss
    24 Apr 2009
    ive had no issue with hamachi for a general VPN tunnel and games have worked a treat with good pings
  7. jaydeee
    jaydeee What's a Dremel?
    25 Apr 2010
    gArena may be a good alternative specially for gaming.
