Storage hard drive ticking
Discussion in 'Tech Support' started by disturbed13, 19 Jul 2012.
  1. disturbed13
    disturbed13 Minimodder
    28 Nov 2008
    i have 3 hard drives in my PC
    a primary 1 TB HDD
    a 1.5 TB HDD for storage
    and another 1 TB HDD that is ment to be the clone of the primary
    right now i am hearing a ticking sound coming from one of them
    does anyone have any advise on how to tell which one is ticking?
  2. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    leave os drive plugged in and boot
    turn off if no noise add another drive back in boot
    keep going till u find the annoying tick ;)
  3. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Use the old mechanics trick, press a screwdriver upto the casing of each drive then press you ear to the butt of the screw driver, obviously being carefully not to accidentally short anything out.
  4. munkey
    munkey What's a Dremel?
    24 May 2012
    Great idea! But unless the drives are in separate cages or otherwise physically isolated from eachother it'd be hard to tell the source of the noise.
    If you're confident you can do this without shorting anything out I'd say this could definitely be a good place to start, then try Big_Malc's suggestion to confirm which drive is failing.
    Also when you disconnect the drive(s) in question make sure you unplug the power too since a drive will still turn itself on even if there isn't a data connection.
  5. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    That how i've determined which of mine was dead, simplest things work
