Help!!!!! Hard Drive Making Weird Noises!!!!
Discussion in 'Hardware' started by madmodder, 10 Nov 2004.
  1. juzzwuzz
    juzzwuzz What's a Dremel?
    4 Jan 2004
    They are not encased in a vacume if you look at the HDD there is abreathing hole that says 'Do not cover' They have holes to allow some heat to escape.
  2. sheardjr
    sheardjr Minimodder
    7 May 2003
  3. juzzwuzz
    4 Jan 2004
    They might only be on the older HDD's as my 13GB Quantom Fireball hase two, but I guess they are for the motors then. :duh:
  4. mikeuk2004
    mikeuk2004 What you Looking at Fool!
    3 Sep 2004
    Air Holes!!!!
    Yes maybe forthe moters but not the platters as alreadymentioned.
    If the slightest spec of dust got on a platter or the heads thenyou will get alot of bad sectors and could ever crash the drive.
    Why do you think there are very few hard disk modders. Puting in clear windows etc. Because once opened and the dust get in your doomed. And those that have modded there disk have usally only done it to old disks and if they die it doesnt matter. And those lucky enough that have a working drive after the mod may not have a working drive for a long time.
    The disk drives are completly sealed from the outside atmosphere.
    I would think larger hard disks would now come with fans attached to the outside or will start happening soon. The bigger the hotter and they cant rely on a persons case cooling system. So people dont cool.
    I bet we will start seeing hard disk manufactures selling the drives with fixed fans on the outside taking up 2 3 1/2" bays.
    my 200GB's get really hot.
  5. TMM
    TMM Modder
    12 Jan 2004
    yup, The motor is what makes all the heat ;). The thick metal casing acts as a heatsink for the motor, and heat exits the hdd mainly through the sides.
    Most likely we'll be seeing more and more harddrives with sides like heatsinks (not sure how to put this).. just look at the WD Raptors:
    http://www.westerndigital.com/en/products/Products.asp?DriveID=40
  6. juzzwuzz
    4 Jan 2004
    Sorry for going off topic, kinda :worried:
    Do the raptors make a huge amount of noise?
  7. Krikkit
    21 Jan 2003
    They make quite a bit of noise, but if you stick it in one of those Silent-Drive thingies it'll be about the same as a normal drive. I don't really mind how much noise mine makes, it doesn't bother me. :)
    (If you're thinking of leaving your rig on overnight, you'll probably not notice it really when you're tired enough...) :)
  8. Firehed
    15 Feb 2004
    I can't hear mine at all except during a defragging and just barely then. And my rig is quiet. Although they're in the zalman holders.
    There's actually a superfine filter type thing so dust doesn't get in through the air hole, although I'm almost 100% sure that's solely for pressurization reasons (so if you bring your HDD in an unpressurized airplane it won't explode, like in the cargo area)
  9. SpeedFreak
    SpeedFreak What's a Dremel?
    28 Mar 2003
    HDD's are not in a complete vacum - they are just designed to keep dust out...
