Networks [HELP] how to boost up the signal of my wireless router?
Discussion in 'Hardware' started by zhenboy, 14 Oct 2004.
  1. zhenboy
    zhenboy What's a Dremel?
    23 Dec 2003
    Hiya
    I've been using my Belkin54g wireless router for a year in my old house.(no big issue with the signal)
    Recently I've moved to a new flat. Put the router in one of my mate's room.
    Its about 17 meters from my rig. (two wooden doors and walls in between my room n his) Dunno why the signal is NOT stable at all...connecting speed is like 5.5M then 2M or even 1M then it drops...
    The wireless card im using in my rig is a PCI Belkin 54g one (not those PCMCIA to PCI ones).
    I also have an apple powerbook (new model) with airport extreme.
    The strangest thing is that my powerbook can work around my rig in my room for around about 11mb/s( not very stable as well )
    Is there a way of getting the signal boosted?
    I heard that I can add a new AP to the network, this cost me the price of a new AP or router.
    Or i can add an antenna to the router, a big antenna can broadcast for a mile or something...I really dont want to add that thingy to my room!! And i check my router, the antennas on the router are fixed ones..cant be replaced (stupid belkin)
    So is there any other solution?
    Anyone knows how to make a signal booster? DIY a boosting antenna?
    Thanks a lot :waah: :waah: :waah:
  2. zhenboy
    23 Dec 2003
    Anyone??
    Sigh...I think I ll juz buy an airport express to extend the exsiting network then...
  3. hk
    hk Powered By Duracell
    4 Jul 2002
    1. Look for firmware that will let you boost the power output of the transmitter.
    2. See if you can hook up a higher gain antenna to it.
    3. Try repositioning it.
    4. Change the channel that its transmitting on, there might be other kit around interfering with it.
