Help! Need A Program Start/ Stop Timer.
Discussion in 'Software' started by proweb, 14 Dec 2007.
  1. proweb
    proweb More is Always Better!!!
    11 Dec 2007
    I'm looking for a program that will automatically start and stop a PC application (play music) at desired times of the day. I have set up a computer for music and would like it start and stop at say 9 am and 5 pm without having to reset the program every day. I don't mind paying for a program like this but a free one would be preferred.
  2. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Might the Windows Scheduled Tasks work good enough? (But I'm not sure if that program exists in WinXP or Vista.)
  3. proweb
    11 Dec 2007
    It will start the program but not the music.
  4. mm vr
    18 Nov 2007
    Oh yea, didn't think about that...
    But maybe with a macro?
  5. capnPedro
    11 Apr 2007
    You need two scheduled tasks, one to start and one to stop.
    c:\start.bat
    Code:
    @echo off
    "C:\Program Files\Windows Media Player\wmplayer.exe" /Task:NowPlaying /prefetch:1 "C:\playlist.wpl"
    (change C:\playlist.wpl to point to the real playlist file)
    c:\stop.bat
    Code:
    @echo off
    taskkill /im:wmplayer.exe /f
    Then schedule start.bat to run at 9am, and stop.bat to run at 5pm.
  6. Cabe
    Cabe What's a Dremel?
    14 May 2002
    batch file programming, is there ANYTHING it cant do?
  7. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    Get your scheduled tasks and point it to the playlist if you are using Winamp, used it for years. And it shuts down too.
  8. proweb
    11 Dec 2007
    I'm setting up a computer for our local Chamber of Commerce to play music automatically. There is no one in the office during the weekends so they wanted and easy way to have the music come on with out having to go into the office in the morning to turn it on and then again at night to shut it down. They are using MediaMonkey right now as it is the only one they understand. Don't know much about batch files but will try that and see if I can get it running. Thanks for the help
  9. proweb
    11 Dec 2007
    I can get media player to start but it won't shut the program down. I used a blank file to get the music to stop but the program is still running. Any suggestions?
  10. Glider
    Glider /dev/null
    2 Aug 2005
    Compared to Linux shell scripting? 99% of the tasks (Batch can't do...)
