Modding help with top!
Discussion in 'Modding' started by H4z4RD0uS, 1 Nov 2003.
  1. H4z4RD0uS
    H4z4RD0uS What's a Dremel?
    19 Oct 2003
    ok ive seen some nice works of art (cases) and i wanna know, can i cut my top and then add that cage looking thing (i think its called mesh) and have 2 92mm fans under it blowing air or something?
  2. Miku
    Miku What's a Dremel?
    11 Mar 2003
    Yes, you can use the mesh. It'll keep your fingers nice and safe ;)
    So you wanna stick two fans on top of each other? If so, are you going to bolt them to the top? If you are, you just have to use slightly longer bolts and there you have it
  3. H4z4RD0uS
    19 Oct 2003
    ok
    where can i purchase a mesh and i didnt want the fans on top of eachther, i want em vertically alligned
  4. Dazbo666
    Dazbo666 What's a Dremel?
    16 Dec 2002
    Aluminium mesh available from auto/car repair shops?!
    Probably cheaper than buying "specialised" modding supplies too
  5. H4z4RD0uS
    19 Oct 2003
    can i get it in my size? or i have to cut?
  6. H4z4RD0uS
    19 Oct 2003
    do you mean that all i gotta do is put the fan under and screw it?
  7. Dazbo666
    16 Dec 2002
    If you go to an independant garage and speak to them nicely, I'm sure they'd be willing to cut it for you...
    (I would think that the larger shops/chains would be more interested in selling bulk or prepackaged amounts)
  8. H4z4RD0uS
    19 Oct 2003
    how do i stick the mesh? super glue? and answer my fan question plz
  9. Dazbo666
    16 Dec 2002
    Re: ok
    Side by side/next to each other?? Just make sure there's enough room underneath the mesh if the main bodies of the fans are going inside the case??
    You MAY need to use some washers depending on the size of the holes, but yes that should be possible.
    Making sure the mesh is slightly larger than the hole its covering, you could either stick direct to the inside of the case with glue or glue some bolts to the inside of the case near the edge of the hole, attach the mesh on to the bolts, and screw the nots over the ends of the bolts??
  10. H4z4RD0uS
    19 Oct 2003
    this may sound newbish, but whats a bolt!
  11. H4z4RD0uS
    19 Oct 2003
    so i can buy a mesh and split loom from auto zone?
  12. Dazbo666
    16 Dec 2002
    Use bolts similar to this (but make sure the thread goes all the way up to the head of the bolt) - and then tighten from the inside of the case by screwing a nut on to each one...
    As for the mesh and the loom, yes you should be able to get them both at your local auto shop.
  13. H4z4RD0uS
    19 Oct 2003
    can someone gimme a more detailed way of putting the mesh using bolts?
  14. Knipex
    Knipex What's a Dremel?
    18 Sep 2003
    I personally wouldnt attach the mesh using bolts as it will sag.
    Attach the fans using 4 bolts and attach the mesh using a glue or body filler. The advantage of bodyfiller is you can tidy the edges and make it look neat. Then paint.
    With patience you could get something like
    this
  15. H4z4RD0uS
    19 Oct 2003
    where can i
    where can i get body filler?
  16. H4z4RD0uS
    19 Oct 2003
    hey wait! do i have to mke plexi and under it mesh?!?!!
  17. Dazbo666
    16 Dec 2002
    Here's one that was used
    Just check out the various modding sites for "stealthed blowhole"/
    Sorry Bit-Tech, but I couldn't find a detailed guide here right away :duh:
  18. Knipex
    18 Sep 2003
    Body fillerand mesh can be bought at any automotive store.
    No you dont need to use plexi, mnpctech just decided to use it on the application I linked to. Thats the great thing about modding you can do what You want.
  19. Dazbo666
    16 Dec 2002
    Body filler also available at the auto shop where you'd get the loom and the mesh.... very convenient.
    Also you wouldn't have to put plexi as well as the mesh, but that could solve the sagging problem
