Notebooks Hinge question
Discussion in 'Hardware' started by BrokeEnthusiast, 28 Aug 2005.
  1. BrokeEnthusiast
    BrokeEnthusiast What's a Dremel?
    28 Mar 2005
    Well I bought this laptop broken and after i took it apart i found the problem and fxed it. But I bent this metal piece that I think was a heat shield kind of so i took it out and lost it..... :duh: but as i was putting it back together i got it all except this one hinge and that shield must have had the screw holes for it but anyways I need a solution to get this hinge back together. I thought about drilling a hole for it but i looks like the heatsink is in the way. here are the pictures. please help!!
    http://img.photobucket.com/albums/v310/BrokeEnthusiast/DSC00530.jpg
    http://img.photobucket.com/albums/v310/BrokeEnthusiast/DSC00532.jpg
    http://img.photobucket.com/albums/v310/BrokeEnthusiast/DSC00531.jpg
    http://img.photobucket.com/albums/v310/BrokeEnthusiast/DSC00529.jpg
    http://img.photobucket.com/albums/v310/BrokeEnthusiast/DSC00533.jpg
  2. BrokeEnthusiast
    28 Mar 2005
    I need helps with this asap. Any ideas will help. I need this laptop for school.
  3. BrokeEnthusiast
    28 Mar 2005
    um... bump, please help
  4. onarahosting
    onarahosting What's a Dremel?
    17 Aug 2005
    anyway to make yourself a bracket from aluminium or something and attach it? might have to make two and replace thge other side as well. Would look so so but might work
  5. thecrownles
    thecrownles What's a Relix?
    27 Feb 2004
    edit, never mind, wrong Idea.
  6. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    umm, you could try altho it may not be the best, to bend a peice of semi thick material and tap it, and mount it to the back, or you could just, find the part, honestly how far could it have gone?
