Modding holding mesh in place
Discussion in 'Modding' started by Vaz, 7 Mar 2007.
  1. Vaz
    Vaz What's a Dremel?
    23 Jan 2007
    Hi guys,
    for my project im considering cutting large areas in my computer case's side panels and replacing them with mesh. What's the best way to hold the mesh down onto the panels?
    Glue or nut & bolt or something else? I havnt got access to any advanced tools.
    thanks -
    Vaz
  2. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    you can use bolts, rivets, bondo, epoxy, some fiberglass, super glue (i wouldnt) pretty much anything that is used to hold something to another thing would probably work. if you want it permanent (im guessing you do) you could use JBweld.
  3. bumfluff
    bumfluff What's a Dremel?
    18 Aug 2006
    Without advanced tools, epoxy resin is great, or if you are a tape guy try the double sided tape used in mounting mirrors.
  4. theurgy
    theurgy What's a Dremel?
    8 Oct 2004
    I used glue for my mod.
  5. B[x]
    B[x] What's a Dremel?
    3 Jul 2006
    I vote for 3M brand double sided tape.
  6. Rage.
    Rage. What's a Dremel?
    3 Mar 2007
    id suggest using epoxy resin as well or even super glue but super glue probably isnt all that super enough for mesh.. also nuts and bolts as suggested before work great.
    Thanks,
    Rage.
  7. Vaz
    23 Jan 2007
    Is glue from glue gun okay?
  8. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    It should be a pretty good thing to use actually since the glue sticks to anything and it will surround the mesh wires giving it a nice hold. Personally I'd go for it :)
  9. theurgy
    8 Oct 2004
    Yeah as long as you're careful with the glue gun and not get it in a place where it's visible.. take it from me.. it's almost impossible to get glue from a hot glue gun out of those holes...LOL
  10. Damouse
    Damouse Thats no moon!
    27 Jan 2007
    i second the glue gun vote, and move to see results as soon as possible.
    The senate is ajourned.
  11. Rage.
    3 Mar 2007
    ive used super glue for mine and DAM it is good. Seriously i recommend it.
  12. inzane86
    inzane86 engineer with an axe
    15 Jan 2004
    I vote for glue gun. I have used it many times.
