Other Homelab Ideas/Planning
Discussion in 'Hardware' started by Byron C, 16 May 2024.
  1. Byron C
    Byron C I was told there would be cheesecake…?
    12 Apr 2002
  2. Andersen
    Andersen Morally questionable and ethically wiggly
    25 Nov 2002
    Hehe my confusers are named after ancient greek deities
    Hyperion, VM host
    Erebus, primary vDC
    Phanes, secondary vDC
    Nyx, NAS + third DNS server
    Aion, planned big NAS
    Tartarus, gaming PC, kinda broke my rule of renaming a confuser when the CPU socket changed last year
    Artemis, laptop
    Takahe and Weka are flighless bird species, just like Tux. Phones and tablets are whatever default names
  3. RedFlames
    23 Apr 2009
    TIL you can, using the hyper-v default switch, access vms via
    Code:
    [hostname].mshome.net
    as well as/instead of the ip address
  4. Byron C
    12 Apr 2002
    Yeah, that seems sensible… I mean… who’d give their phone a dumb device name?
    :worried:
  5. RedFlames
    23 Apr 2009
    ikr... what lunatic names something Byron...
  6. Byron C
    12 Apr 2002
    My mother :grin: :thumb:
    VictorianBloke likes this.
  7. Byron C
    12 Apr 2002
    Proxmox cluster is go!
    Yes, I called a host 'gigglebyte', deal with it :grin: - it's got a Gigabyte motherboard, so... ¯\_(ツ)_/¯ . I was also considering 'jigglebyte' and 'gigashyte' :grin:
    I'm planning to upgrade the bejesus out of that host and slap in 128GB RAM and a 16C/32T Xeon CPU. A good chunk of its resources will be allocated to a TrueNAS Scale VM, but there'll be more than enough compute capacity left over to move my current docker host over to it. Right now it's just a bare board lying on a cardboard box, but tomorrow I'm going for a little jaunt to Brum to pick up a case from Mr Crappy (@The_Crapman). So long as I can figure out device passthrough in Proxmox I should be able to migrate the array off my Microserver this weekend :happy:
    Side note: ZFS portability is freakin' awesome. Just slap the disks in a new host and import the existing pool(s) - job done!
    BazzUK, meandmymouth and RedFlames like this.
  8. RedFlames
    23 Apr 2009
    showoff :p
    I have to shut down my solitary VM bc it saps too much resources making doing other things painful.
  9. andrew8200m
    andrew8200m Multimodder
    4 May 2009
    Now that is pretty cool!
    Byron C likes this.
  10. RedFlames
    23 Apr 2009
    it has been 0 days since it was -
    DNS
    Drivers
    A re-compile of the Linux Kernel
    SELinux
    :wallbash:
  11. RedFlames
    23 Apr 2009
    So what are the specs of squiggletits and the dell box?
  12. Byron C
    12 Apr 2002
    The Dell is an Optiplex 5040 SFF with an i5-6500 (4 core/4 thread) and 16GB RAM, and the gigglebyte is an i7-5820K (6 core/12 thread) also with 16GB RAM.
    For the Gigabyte system, I've recently ordered 64GB ECC registered RAM and a Xeon E5-2680 v4 (14 core/28 thread). More than enough capacity to run the workload of my current Docker host as well as my TrueNAS Scale instance. I think I'm going to turn the Optiplex 5040 machine into a router - my current router is MiniITX thin, which limits my ability to install dedicated LAN cards.
  13. RedFlames
    23 Apr 2009
    my ambition outstrips my ability and my wallet...
    but trying to virtualise even a homeassistence docker container on my pc is no bueno...
    i jelly and/or envious
    meandmymouth likes this.
  14. Cheapskate
    13 May 2007
    It could have been a bad attempt at Brian. :) I had a ton of relatives born before the '50s with misspelled names.
  15. Byron C
    12 Apr 2002
    So… I’m on a mailing list/community group set up by the local police. There was a bulletin on there recently warning about increased vehicle crime in the area, and it got me thinking about the CCTV camera over my driveway that isn’t currently recording anywhere…
    So I started looking at NVR options and came across Frigate, it’s designed around object detection and tight Home Assistant integration. Intriguing. It relies on either a Google Coral TPU or a GPU to do the object detection. But I don’t have a beefy enough GPU spare, and initially I could only find the USB version of the Coral TPU for £SpendyMoney (£80). Back to the drawing board.
    I poked around the Coral site and found that they also do an M.2 A+E key version, designed to slot into the same connector used by WiFi cards in laptops & mini desktops. Further poking for UK distributors revealed that RS in the UK have it for £25 (plus shipping). The spare HP 260 Mini desktop has a PCIe M.2 slot of the same type. Result.
    Two PoE cameras, a PoE switch, and the aforementioned accelerator are now on their way to me. I already have a USB Zigbee dongle, networked storage, a powerline network link to the shed, and a spare PC to run it all. So I guess I’m getting back into Home Assistant then… :grin:
    IanW and meandmymouth like this.
  16. RedFlames
    23 Apr 2009
    You're on a police list, eh?
    As for HA, as i said, my home is dumber than I am so aside from a weather forecast widget I can't find a use case for it [for me].
  17. creative
    creative 500rwhp
    23 May 2014
    I use Shinobi docker on my unraid box for my cctv and the peek app for outside access to it.
    Byron C likes this.
  18. Byron C
    12 Apr 2002
    One of many :grin:
    Yeah I’ve used Shinobi in the past. Can be a bit of a pig to configure, and the UI isn’t the best, but it’s a solid system.
    One of the things I want to do is try and integrate this with Apple HomeKit, and there are a lot more options for that with an NVR that’s tightly integrated into Home Assistant. I’m not so sure about HomeKit Secure Video, but one step at a time :happy:
  19. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    I've just connected to my webdev RPi4 using your little tutorial. I may have an SSH induced boner!
    Byron C likes this.
  20. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
    We'll be in touch.
    Arboreal and Byron C like this.
