Storage Homelab Project 2024
Discussion in 'Hardware' started by meandmymouth, 6 Mar 2024.
  1. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    I was all excited about having 2.5Gb networking and even a single 10Gb port and then I have to go and watch this.
    Sigh.
    Arboreal, David and Byron C like this.
  2. RedFlames
    23 Apr 2009
    there's ait's smaller, cheaper cousin too...
    meandmymouth likes this.
  3. meandmymouth
    15 Sep 2009
    Updated proposed network diagram now that I have a 2.5Gb switch and the additional nab6 lite mini PC. It's a managed switch so the plan is to create a storage VLAN which the proxmox nodes can use for Ceph (just the 3 nodes in the office, not the one in the living room), speedier back ups and replication between truenas and synology.
    I'd still need to get a 10Gb NIC for truenas (got the Synology one but they will have to run at 2.5Gb at the switch only has a single 10Gb port).
    The more I look at the diagram the more I think "just get a proper rack and unifi gear like the Pro Max switch and Max gateway and do it all properly in the office" but then money...
    Arboreal likes this.
  4. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
  5. RedFlames
    23 Apr 2009
    Behold the intricate network map [this is all in the same room fwiw]
  6. Cookie Monster
    27 Aug 2003
    @RedFlames What did you use to create this diagram?
  7. RedFlames
    23 Apr 2009
    Excel
  8. Cookie Monster
    27 Aug 2003
    Not what I was expecting, but if it works. I don't have Offfice, but I've never thought of doing it on a spreadsheet. I've made them in the past and always hated the way they turned out, maybe I'll give Google Sheets a go.
    RedFlames likes this.
  9. meandmymouth
    15 Sep 2009
    I was not expecting this either.
    Don't tempt me, not that I ever need anyone else to tempt me. The Ubiquiti Pro Max 16 feels like a nice half measure. It'll sit on top of the lack rack next to my PC, had 4 2.5Gb ports for the proxmox cluster (leaving one spare) and 2 10Gb ports for the storage servers. That could be job done then.
    It's a shame TP-Link don't have a similar switch as keeping everything Omada would be useful, but then again if we ever find a new house that's when I'd like to go all in on a proper rack and Ubiquiti. So I guess getting the Pro Max 16 is both finishing the project and planning for the future - flawless logic!
  10. Cookie Monster
    27 Aug 2003
    Do I need to repeat myself? I'm quite happy with my setup so far. I'll create a thread once I've put another hole in the wall to run the power and wired in my Virgin router properly.
  11. meandmymouth
    15 Sep 2009
    It comes with wall mounting brackets as well so it doesn't even have to go in or on top of the lack rack.
  12. Cookie Monster
    27 Aug 2003
    Do you need any more convincing?
  13. RedFlames
    23 Apr 2009
    What were you expecting? MSPaint? :grin:
  14. meandmymouth
    15 Sep 2009
    Challenge accepted.
    I just need to find out where I can buy one from. Ubiquity only had it on its EU store.
  15. meandmymouth
    15 Sep 2009
    OK, taken the plunge and bought the switch direct from the EU store. After this weekend NO MORE HARDWARE CHANGES. I shouldn't have to make any more tbh
    I'll be having a fairly decent clear out next week to recoup some money.
    Cookie Monster likes this.
  16. Cookie Monster
    27 Aug 2003
    Damn it, I didn't think about this possibly back firing and making me skint. Please peddle your wares on a different forum.
  17. meandmymouth
    15 Sep 2009
    Ubiquiti gear is quite good... this is a problem.
  18. meandmymouth
    15 Sep 2009
  19. meandmymouth
    15 Sep 2009
    I've had a little hardware reorganisation.
    Firstly, replaced the managed tp-link switch with an omada managed switch so now the router, switch and AP can all be managed together.
    Secondly, Synology now connected to the other 10Gb port on the ubiquiti switch, freeing up a 2.5Gb port.
    Finally, main rig is now in the NR200P Max case, which is nice and tidy. Smaller case but can fit bigger GPUs. I've also put the 4060Ti in the main rig and Titan Xp on the AI rig.
    Software.
    As mentioned, router, switch and AP all centrally managed now through the omada controller. The ubiquiti pro max 16 seems to work fine as well so while it's a bit of a pain to manage 2 ecosystems it could be worse. It's giving me experience working with both so benefit there.
    VLANs starting to get set up and deployed NginxProxyManager to an LXC in the new DMZ so happy that that works.
    New VLANs to be created, services migrated to updated VMs/LXCs which will all be managed via ansible (probably). I'd use terraform as well for proxmox but the provider is a pain.
    Progress is happening, slowly.
  20. meandmymouth
    15 Sep 2009
    Progressed stopped for a few months as you can tell.
    With the latest TrueNAS version ditching K8s and going plain docker with compose support I am considering consolidating a few things now. For example Nextcloud, which I run using the All-in-One deployment, could run directly on TrueNAS now. I could do the same for my media apps which are all deployed with docker compose.
    The best part of the new TN version is the ability to add disks to a vdev and expand it. I've had an 8TB drive sat as a hot spare but originally planned to rebuild the pool to have all 5 disks instead of 4. That's now done and it was very easy.
