Modding How do you splice wires?
Discussion in 'Modding' started by Zion, 16 Aug 2004.
  1. Zion
    Zion What's a Dremel?
    11 Apr 2004
    just wondering how one would go about doing this
  2. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    I either use my teeth or a splicing tool of cutting tool
  3. play_boy_2000
    play_boy_2000 ^It was funny when I was 12
    25 Mar 2004
    Im a teeth man myself :D
  4. mushky
    mushky gimme snails
    24 Mar 2003
    plenty of pepper and a little salt to taste.
    to splice wire: I use a soldering iron and a bit of tape, or a crimp or screw terminal. Depends how much room I have and how tidy it needs to be.
  5. SilentNoise
    SilentNoise What's a Dremel?
    4 Jan 2004
    Wire strippers most of the time, then I'll twist the ends together so the wires form a straigth line (not that nasty T-shaped twist), then salder them together and heat shrink it up..... it's the only real way to do it clean and properly.
  6. LAGMonkey
    LAGMonkey Group 7 error
    4 Aug 2004
    solid core wirse i use my teeth, but multi-core i use pliers.
    but remember to turn off/ dissconect the wires BEFORE you start to strip the wires with your teeth :wallbash:
  7. mushky
    mushky gimme snails
    24 Mar 2003
    How do you use your teeth to join 2 wires?
  8. jaguarking11
    10 Dec 2003
    I thought he meant striping them :duh:
  9. Firehed
    15 Feb 2004
    I would really hope so. That or you're a dentist.
    Splicing wires? Solder them together or strip them and get some sort of joiney thing (one of the screw-on deals or some crimping type thing)
  10. Ben '71 1200
    Ben '71 1200 What's a Dremel?
    16 Aug 2004
    Hi, long time lurker, first time poster..
    I tend to use "chocolate block"* connectors if I'm lazy or I'll do it properly and twist together, solder and heatshrink if it's on show.
    * My dad's an electrician, and he's always called them that, though I very much doubt that that is their proper name!
    EDIT: typo
  11. mushky
    mushky gimme snails
    24 Mar 2003
    I've heard them called that before too :)
    hi, by the way :)
    i think the correct name is terminal strip or strip terminal but thats quite an ambiguous description if you ask me.
    Everyone should have these in a drawer at home ;)
  12. Ben '71 1200
    16 Aug 2004
    In the drawer? I raid father's van; also useful for blagging zipties, electrical tape, multimeters, cable, random switches...... :D
    Terminal strip eh? I'll remember that.
  13. Firehed
    15 Feb 2004
    Well most people don't have a van full of electrical parts. Electricians being the exception... so a drawer or bin or something to that extent would be safe for most people.
  14. Fronzel
    Fronzel What's a Dremel?
    9 Mar 2002
  15. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
