How far have you pushed the voltage on your memory?
Discussion in 'Hardware' started by jetsetjimbo, 21 May 2003.
  1. Mister_Tad
    27 Dec 2002
    iceman, what sort of voltage were you running your ram at (everything at for that matter) to get your recent 1200mhz fsb achievement?
  2. Iceman
    Iceman Staff
    13 Feb 2003
    default volts since there's not a chance in hell i'd get the RAM to run at DDR600! I had to use a memory divider to bring my RAM down to just over DDR400 speeds and my RAM's happy at that speed with stock volts. Chipset voltage was 1.6v (1.5v default) CPU voltage was 1.6v in bios so very low for me :)
  3. Mister_Tad
    27 Dec 2002
    whens it going to go all freezy frozen then? as it doenst even look like its anywhere near its limit
    if you got ddr400 to run at ddr530 have a go with some ddr466, could have potention to run at 600, maybe?
    EDIT: by freezy frozen i mean in the vapo :)
  4. NiHiLiST
    NiHiLiST New-born car whore
    18 Aug 2001
    <offtopic>Mr Tad, what's that binary in your signature? It's not anything sensible in ascii, unicode or hex :(</offtopic>
  5. Mister_Tad
    27 Dec 2002
    each is an 8 bit int, convert that into the corresponding ascii char
  6. CatKing
    CatKing What's a Dremel?
    10 Nov 2002
    yes, it really needs running the ram in high voltage (above 2.7v) in aggressive setting to keep the system stable or sometimes it even refuses to boot if u dont. however make sure your ram has a good heat spreader.
  7. NiHiLiST
    18 Aug 2001
    Ah, so sort of quasi-ascii coded then :)
  8. NiHiLiST
    18 Aug 2001
    Hmmm, that gives a lot of gibberish by the way.
  9. Iceman
    Iceman Staff
    13 Feb 2003
    I've not had much luck with DDR466 tbh, since it's either made by OCZ or TwinMos. The OCZ stuff I've taken to DDR510 but after that it just dies. I was stupid and left my Vapo PSU at home so it's going to be next week before I can power it up again :)
  10. Mister_Tad
    27 Dec 2002
    giel makes ddr466 as well some mains voltage through it should do the trick :D
  11. sp00n
    sp00n What's a Dremel?
    21 May 2001
    Mains voltage? thats sooooo last season. I hooked up my 16Mb 72 pin EDO dram to the National Grid whilst dipping it in a liquid helium/four-leaved clovers solution in order to get it to DDR666!!! :D :D :D
  12. NiHiLiST
    18 Aug 2001
    ...lol :clap:
