Guide How to add a little art
Discussion in 'Modding' started by Skaal-tel, 4 Feb 2004.
  1. Skaal-tel
    Skaal-tel What's a Dremel?
    12 Jan 2004
    I'm not even sure if this can even really count as a guide- but here it is!
    In the process of designing my PC I decided I wanted my main inspiration to make a strong appearance. I wanted my non windowed panel to be a little more interesting than plain red, and needed to really bring out my theme. (Samurai)
    When I was working at the ford dealership nearby, I had a pal in the bodyshop paint my case with red and black- and had him mask off a piece of the panel so I'd have a mostly red part black panel.. the black is the ground, with a slight roll to it.
    Usually the process dictates that you promptly clearcoat on top of the auto paint, but I took the panel home, and with a can of black paint and a relatively small paintbrush painted my designs onto the side.
    The trick to painting with auto paint is to do it right the first time. If you have to go over anything you've already painted it will smear and show the underlying colour.
    The solvents in the paint are really strong, and the lower layer hasn't bonded to anything much yet. Make smooth long strokes and you ought to be alright- and it pays to pay close attention to a reference piece.
    Make all your strokes in one direction, no kindergarten style fill in the lines here, try to make all strokes horizontal or vertical, whichever is most comfortable for you.
    So long as you put the clearcoat on within a day you don't have to worry about a lack of adhesion, and you'll still acheive a pretty nice mirror finish, despite your brushstrokes being immortalized.
    The clearcoat bonded just fine, and with a little car polish and wax you'll be golden.
    I didn't have a digicam at the time of painting.. so sadly no pics of the progress- but I can show a finished product pic :)
    Hope this inspires a few more interesting designs.
    Skaal-tel out!
  2. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Very cool! :thumb:
  3. MarcelloRupelli
    MarcelloRupelli What's a Dremel?
    30 Jul 2003
    Wow, I really like the way that looks! Nice work :) So the black you used is the same paint as the bodyshop used? Like black basecoat with the activator already added.
  4. Bluebark
    Bluebark What's a Dremel?
    1 Sep 2003
    Looks real good…even I would be proud of the job. I noticed you still have swirl marks and hazing on the paint job. If this is a new paint job, ask you’re bro at the shop to hit you’re case with some liquid ebony in a few months (got to let it cure) and then wax. It should get rid of all the swirl marks… :thumb:
  5. Skaal-tel
    12 Jan 2004
    thank you all- yes its black basecoat with activator, great for touchups etc.
    as for the swirl marks, those are a result of my polishing/waxing efforts. And they're invisible unless you hit with a camera flash. of course. hmm..
  6. Bluebark
    1 Sep 2003
    Swirl marks are always only visible when the light shines on them. My comment was merely a suggestion on how to get rid of them…nothing more.
    P.S. FYI...You never wax a fresh paint job...
  7. Skaal-tel
    12 Jan 2004
    aaaaaaaaaaah k.
    No, I didn't wax it right after it was painted. I waited about a month or more- till I got around to it. :cooldude:
    I've never heard of black ebony before, is it available in Canada? What exactly does it do?
  8. Bluebark
    1 Sep 2003
    Liquid Ebony is an ultra fine compound agent. It is also referred to as a finishing glaze. It comes in a squirt bottle and you apply it with a buffer with a real fluffy bonnet. As the Ebony is worked into the paint it break down into ever smaller particles as it starts to dry. It is very critical to make sure the bonnet is ultra clean. Any foreign material on the bonnet will scratch the paint surface.
    The shine is great...I used it all the time. Especially when doing black paint jobs. If you do it right…it looks like you can reach right into the paint.
  9. h3x
    h3x What's a Dremel?
    23 May 2004
    I love this design.. I hope you wouldn't mind me using a similiar idea. Where do you think I could find the paint, and the clear coating? Maybe an auto store? Where did you get the design for the samurai army? I am interested in doing something similiar.
  10. Twunka
    Twunka What's a Dremel?
    12 Feb 2004
    he got it from a game called shogun: total war
  11. h3x
    23 May 2004
    I have that game, and i didn't realize it was from that. But I was able to find some shots similiar to it that 'm going to use. I think I'm going to do something like this:
    hopefully you won't think I'm copying you too much.
    can anyone give me advice on how I should paint this and coat it?
  12. I'm_Not_A_Monster
    I'm_Not_A_Monster Hey, eat this...
    22 Dec 2003
    :blah: total rip!!! :D
    i like that blood splat for the contrast, that looks cool.
  13. h3x
    23 May 2004
    Just because i like his idea dosnt mean i can't make it look better. :rock:
  14. Ubermich
    Ubermich He did it!
    21 Jun 2002
    AWESOME job with the brush. No way I could've done that. (no sense of line length) Very impressive outcome too.
  15. I'm_Not_A_Monster
    22 Dec 2003
    word :rock:
    we should have a black panthers smilie, you know, like :rock: but a fist straight up and all :blah: (but tougher looking) :fightthepower:
  16. Sniper-X
    Sniper-X What's a Dremel?
    27 Mar 2004
    Sweet paint job :) and great finish :) I worked in a car detail shop doing the buff outs on new paint jobs (after they cured of course lol) and we made our own Liquid Ebony ...we took a nice high quality liquid wax and mixed it with a real fine rubbing compound it worked great :thumb: but make sure the surface and the bonnet are totally clean the slightest little material on it will scratch bad ....good luck
  17. D B
    D B What's a Dremel?
    11 Apr 2004
    Awesome !!! ... who needs a window !
    I would not make your own compound to polish the case , if you you use the wrong stuff you'll be sorry . Just ask your friend at the body shop what they use and ask him for some .
    Thanks for the ideas
    DB
