Electronics how to boost power from lcd
Discussion in 'Modding' started by Hekke1664, 25 Feb 2006.
  1. Hekke1664
    Hekke1664 What's a Dremel?
    30 Mar 2004
    I'm using a Matrix Orbital LCD but it can only provide 1A @12V (5V also available). I started searching for a circuit which could supply the fans, but with the 12V (or 5V) from the LCD as a signal. This way the lcd doesn't have to provide the power for the fans, but the psu has to do it.
    I searched for amplifiers, opamps, etc. but haven't found anything useful.
    Most circuits i've found use a variable resistor to control the speed of the fan.
    in short:
    needed :
    variable 0-12V (for fans)
    available:
    fixed 12V (from PSU)
    variable 5V and 12V from LCD (but low current)
    thanks
    Hekke
  2. DarkInferno
    DarkInferno Minimodder
    28 Nov 2004
    Transistor?
    Mosfet?
    How much power do you want to pull?
  3. Hekke1664
    30 Mar 2004
    i need about 2-3 amps.
    i was thinking about a mosfet/transistor, but i don't know what parts to use.
  4. Drastik
    Drastik What's a Dremel?
    10 Jan 2002
    use a relay and pull power from the psu
  5. Confused Fishcake
    Confused Fishcake Minimodder
    25 Sep 2005
    Well, you don't aactually want anything less than 5V, the fans can stall, but the easiest way is to use a high current npn transistor. This will give you about 5V-11.75V, depending on the transistor. Go to any electronics shop and ask for a high gain, high current npn. (High gain will bring the max voltage closer to 12V) Then set the transistor up as a voltage follower:
    12v(from PSU)--->Collector of transistor-->fan +v line connected to emitter of transistor-->Fan ground to PSU ground.
    Then just connect the lcd output to the base of the transistor. That would be the cheapest and simplest way to do it.
  6. Hekke1664
    30 Mar 2004
    thx for the reply
  7. cpemma
    cpemma Ecky thump
    27 Nov 2001
    The gain will affect the ratio of base current (drawn from the LCD) and load current (what the fans need) so with 1A max available most any NPN power transistor will do. TIP31 is a borderline 3A rating, but TIP41 is 6A and common.
  8. madhatter
    madhatter What's a Dremel?
    16 Sep 2003
    Could you tell me if a fan with a 3 pin connection, connected straight in to the matrix orbital [i have an mx4...] draws all its power from those 3 pins? would this also be the case if the fan had 4 led's on it? i'm not sure how those are wired up as i don't have any yet, but i thought someone on here might know.
    thanks!
  9. tech3312
    tech3312 Where's my dremel o.0
    1 Apr 2007
    What is the wattage of the power supply?
