How to ftp????
Discussion in 'Tech Support' started by zhangmaster12, 21 Feb 2007.
  1. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
    how do i transfer files from one computer to another over lan? i have two computers connected through a router by ethernet cables and i was wondering how to transfer movies from one to another over the lan
  2. Buzzons
    Buzzons Minimodder
    21 Jul 2005
  3. Glider
    Glider /dev/null
    2 Aug 2005
    Or just use samba/windows filesharing... That way it seems like the remote directory/drive is a local one. Easy as dandy
  4. zhangmaster12
    11 Jun 2006
    ok so i think ive got this figured out. guildftp was to confusing so i googled and got a thing called winftp. i registered and now i have the server and client.
    how do i make it so other people can download stuff not in my lan and without this program?
  5. Boswell
    Boswell Minimodder
    23 May 2005
    I havn't used this program.. but I imagine that they won't be able to. They will have to use Windows standard filesharing.
  6. zhangmaster12
    11 Jun 2006
    also i noticed that there were two modes, passive and active. wich is faster? with active i could see a kbs and it was no good, 17 kps. but passive i could not see a kps meter and it was about the same speed. is there a way to speed this up? i want like 1mps
  7. crazydeep74
    crazydeep74 What's a Dremel?
    25 Jul 2005
    Why are you convinced to use FTP. Use windows normal file sharing. Jeeze.
  8. sackingz123
    sackingz123 What's a Dremel?
    7 Feb 2007
    x2
  9. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    file sharing is
    a) slower than FTP
    b) if one file stops it stops the entire process
    and PASV and ACTIVE are both the same it wont change your speeds its just how it sets up the connection. (should use ACTIV on a local lan)
    also if you are only getting 7KB/s sommit is really wrong
  10. bubsterboo
    bubsterboo What's a Dremel?
    24 Jan 2006
    I use ultra VNC and Bulletproof FTP servers running as a service on my system. Very handy.
  11. cannon
    cannon What's a Dremel?
    15 Jan 2004
    passive and active only differentiate who establishes the connection for the file transfer.... the client or the server
  12. Glider
    Glider /dev/null
    2 Aug 2005
    And with passive FTP you can detemine the port (range) on which the connection happens (server side)
    And Windows filesharing isn't that much slower... And a lot easier
  13. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    much slower, and not that much easier to do correctly
  14. DougEdey
    5 Jul 2005
    Never had any problems with Windows Filesharing here.
  15. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    biggest annoyance is that if one file fecks, it takes down the rest of the queue, unlike with FTP
    also the over heads are quite large (SMB will get you about 4-5mb/s FTP will get you 8-9MB/s)
  16. zhangmaster12
    11 Jun 2006
    ok, well ive solved some problems, such as the ftp speeed. it was quite easy, i switched from winftp client to smartftp client. now i get around 800kps - 1mps on ftp.
    thanks all.
  17. krimson
    krimson What's a Dremel?
    16 Nov 2006
    if you want other people to be able to connect, you will have to put the ip of your server machine to static, and make it like 192.168.0.2 or something, and then open port 21 to that ip, and then tell people to ftp to your ip, or you can get a dynamic dns client (like no-ip.com or something) and have them go to like ftp - "zhangmaster.no-ip.com"
  18. zhangmaster12
    11 Jun 2006
    :jawdrop: complicated.....
  19. Nath
    Nath Your appeal has already been filed.
    28 Dec 2003
    That's not complicated. Give your FTP server (the computer that people will be able to connect to) a static IP. On your router, set up port forwarding so that port 21 is forwarded to the IP you've given the server. People can then connect via your external (WAN) IP.
  20. krimson
    16 Nov 2006
    if you stop before the dynamic ip stuff, its easy..
    the dynamic ip part is just in case your ISP changes your ip address often... mine changes like once every like 8 months, but some change a lot..
    other than that, its like opening a port for any other program on your router or windows firewall or whatever.
    if you dont know how to do that, i (or probably several others) would be glad to walk you through it
