Modding How to paint plastic?
Discussion in 'Modding' started by monkeyville, 10 Feb 2005.
  1. monkeyville
    monkeyville Evilish Monkey ++;
    3 Aug 2003
    Hey all.
    I am looking at spraying my LCD monitor a nice shade of black however i am a bit of a n00b when it comes to how i should spray things. Only painting i ever did was with a roller.
    What kind of paint should i buy and what should i avoid? I want a very matt finish and don't want it to peel and would like it to look as proffesional as possible.
    Any advice would be much appreciated
  2. Wesker
    Wesker What's a Dremel?
    26 Sep 2004
    Krylon Fusion is excellent for painting plastic
  3. D1lazarus
    D1lazarus What's a Dremel?
    22 Feb 2004
    Yep. Krylon Fusion works great on plastics. Just make sure to take your time and do the prep work and you will have a great result.
  4. Bandit_zoraK
    Bandit_zoraK What's a Dremel?
    29 Nov 2004
    vinyl paint/die works well because the color is actually absorbed into the plastic. I am not sure if there is a large variety in colors, but can go wrong with black :thumb:
  5. emj1s
    emj1s What's a Dremel?
    26 Jun 2004
    painters choice or touch... whichever, worked fine on my xbox, just put at least 1 layer of that primer, then any spraypaint should work, but stay away from metallics as they never really seem to dry.
  6. Rimmer
    Rimmer What's a Dremel?
    16 Aug 2004
    I can paint it for you any colour you like.
    I own the company responsible for painting these
    White Cobra
    Blue Cobra
  7. offroadracer789
    offroadracer789 What's a Dremel?
    9 Dec 2004
    I like using krylon fusion or dye. I'm not a fan of the spray on dye stuff, so i only use dye if the part can fit in a pan.
  8. user0001
    user0001 What's a Dremel?
    8 Sep 2004
    I have a can of Krylon Fusion and let me tell you it SUCKS. On metal that is. Not sure how well it works on plastic but, I would imagine that since that is what it was designed for...
  9. offroadracer789
    9 Dec 2004
    why did you use krylon on metal when it is meant for plastic.
  10. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    for metallics, I generally apply 2 coats of krylon light grey, followed by sanding,then a coat of flat black, 2 coats of clear gloss (most likely future floor wax [yes it's cheap acrylic paint]) and 3-4 coats of the metallic color I want. for normal non-metallics, I just apply a coat of primer, light sanding, then painting the color I want and depending on the finish, clear or flat final coat.
  11. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    Tis made for plastics, why would you expect it to work on metal?
    Sand it well, apply primer, and do lots of light coats. You'll be good to go :thumb:
  12. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    I'd just vinyl dye it, quick easy and looks great after about 4 coats.
  13. user0001
    8 Sep 2004
    I used it metal because it said "also works great on metals....." Had primer in it so I thought that since it was my first paintjob - a single can that could prime and paint was a great idea. It runs quite easily on metal, and just plain sucks compared to the can of duplicolor I picked up.
  14. monkeyville
    3 Aug 2003
    Ok Krylon Fusion is not erasy found in Britain(to the best of my knowledge), so where would i go about getting vinyl die etc?????
    I am in the centre of Manchester i cannot find a single art/hobby shop anywhere. Can anybody recommend one
  15. Leeum
    16 Feb 2004
    Your local hardware store should have it. This is what i use.
  16. monkeyville
    3 Aug 2003
    Cheers at least i know what to look out for now. Now all i need to do is find out where the local hardware store is. Anybody know of one in Manchester??
  17. Whowalks
    Whowalks What's a Dremel?
    28 Feb 2005
    Iv tryed plastic paints and they leave a coating over the plastic and can be easily pealed off Iv used muffler paint for my bike its mat black and seams to be absorbed by the plastic it works great on front pannels for cdrom/dvdrom
  18. Feline
    Feline What's a Dremel?
    17 Dec 2004
    Normally I use vinyl dye whenever painting plastics. A few months back, I decided to paint my monitor black, using Krylon Fusion. After all the prep work and everything, it still looks horrible. I've never had good luck with any Krylon product, and I won't use them anymore.
    I'd recommend either SEM ColorCoat or DupliColor vinyl dye. Both are made specifically for plastics and come in a wide variety of colors. The SEM can be harder to find, but most automotive paint supply stores carry it (as well as many upholstery shops.)
