Hyper Threading Technology Thread
Discussion in 'Hardware' started by metz2000, 23 Nov 2002.
  1. metz2000
    metz2000 What's a Dremel?
    22 Oct 2002
    Hey, this is a thread for any views on Intel's hyperthreading technology. Please post any relevant links below and of course discuss the technology!
    One question I have is this...
    If hyperthreading can be used in CPUs, then why not in GPUs?
  2. KevinOwns
    KevinOwns What's a Dremel?
    13 Jan 2002
    Well, right now unless Intel were to release the technology to nVidia or ATI they would have to start from scratch.
    And honestly, it wasn't that impressing. Sure, it squeezed out a few extra points on the benchmarks, but it wasn't anything that would make a significant performance increase.
  3. JADS
    JADS Et arma et verba vulnerant
    27 Mar 2001
    Question do you run multiple games at once? Hyperthreading only deals with thread level parallelism.
  4. metz2000
    22 Oct 2002
    But if it was hard coded into the game's code, so that textures were handled in a separate thread to another part of the graphics, then this may create a performance gain... I don't know... I'm no expert... just an idea.
    ::Metz::
  5. Hargle
    Hargle What's a Dremel?
    13 Oct 2001
    Generally you have to do things in the graphics pipeline in order so multiple threads here wouldn't be as easy. In games however multiple threads can be used to seperate say rendering and game logic. Game logic might only be run at 10 fps but you would still want to run the renderer as fast as you could to show off your hardware, right. Not necessarily a job that requires multiple threads but it can be used here quite successfully.
    As a rule though inside the GPU everything is done in a very strict order and so any large level of parallelism in the graphics processing would be difficult (and hence probably not worth the extra effort). I'm sure there's plenty of low level threading going on though, but I don't know enough about things at that level to do anything more than speculate :sigh:
  6. xen0morph
    xen0morph Bargain wine connoisseur
    30 Jun 2002
    There would generally be no point in ht'ing teh gfx core, as everything has to strictly be in sync anway.
    Also very complex drivers would have to be written to take advantage of this.
  7. Fowler
    Fowler mmm Cosworth
    20 Nov 2002
    so basically at this time in life the Hyper-threading technology is of not much use just yet?
    Pentium seem to be trying to make a big deal of it so theyre must be somein worthwhile theyre surely!
    Who cares , if it works il use it!
    :hehe:
  8. Loz
    Loz Blah Blah
    16 Apr 2002
    Do you mean Intel? Whether its useless or not they're going to make a big deal out of it as their chip has it and AMDs dont! Whether it makes a difference or not is irrellevant for marketing purposes.
  9. Fowler
    Fowler mmm Cosworth
    20 Nov 2002
    Yes I meant Intel , was in a rush, yes but as a user I want to know if the hyper threading technology will actually benefit intel followers??!
    :confused:
  10. bradford010
    bradford010 Bradon Frohman
    7 Dec 2001
    The point of HT is not to get a straight performance boost but to greatly increase the efficiency of multi-tasking.
    As for Intel releasing the technology, I don't think it's really an issue ;)
  11. xen0morph
    30 Jun 2002
    Wasn't there already a thread about this :D
  12. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    It is somewhat, I remember reading somwhere thet the PS, and PS2 use a processor type that relies heavily aon massive amounts of parallel data between the CPU and GPU. Each one executes several chunks of code at once.
