Modding Idea: Dr Jeckle
Discussion in 'Modding' started by Kickn, 11 Aug 2004.
  1. Kickn
    Kickn What's a Dremel?
    7 Oct 2003
    I was just flipping through my updated science glassware catalogue and had an idea - has anyone ever seen a lot of glassware encompased into any sort of water cooled 'made scientist' project? I just thought it could be interesting to have 'whirl pools', settling tanks, resevoirs, etc.
    What do you think? :idea:
  2. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    That would be cool, like an old Frankenstein movie.... It's Alive.!!!!!
  3. Aa-chan
    Aa-chan AA-CHAN
    8 Jul 2004
    I'd be interested in seeing what it'd turn out like. Providing the water is bright green :D . Alternatively, two watercooling systems with different coloured water.
  4. Kickn
    7 Oct 2003
    I was thinking you could use a reaction vessel type thing to get a neet swirling effect. You would then have to put a dissipation tube -type - thing to settle out any bubbles but it would look cool - you could even integrate a water cooler/heat exchanger into it :)
    add some dry ice and bam!
  5. taliban_raider
    taliban_raider Just some guy; you know
    28 Feb 2003
    Very cool idea, it may have to be on a totaly purpose built loop though, as I think it may restrict waterflow too much for cooling purposes.
  6. Kickn
    7 Oct 2003
    shouldn't too much if you had all the stuff before a res - then a pump then the rad and back out to the blocks.
  7. Twitch
    Twitch What's a Dremel?
    13 Mar 2004
    Be careful you don't get any whirl pools going, cause it might start to put air into your tubes, meaning your watercooling system, meaning bad for your processors heat. But otherwhise good idea
  8. Kickn
    7 Oct 2003
    Thats why I mentioned it would have to have a settling tube - create the whirlpool and then settle out the bubbles before using the fluid.
  9. Nexxo
    23 Oct 2001
    You have to have a pulsating brain in a jar though. It wouldn't look right without a pulsating brain in a jar.
  10. Zidane
    Zidane What's a Dremel?
    27 Apr 2004
    awesome idea.....
    im wondering, can you not use one of those 'agitators' i think they are called, to set up a whirlpool in a res? its like a flat base, and a little thing you drop into the res, and the base has a magnet that spins, dragging the thing in the res round, thus creating a whirlpool.
  11. Kickn
    7 Oct 2003
    I don't think you would need an agitator. I think the fluid would form a whirlpool if you could find a container with a bottom outlet and a side inlet - that would be enough I think. You could mount it on a ring that had little UV led's in side of it and that would make it glow!
    I know down south there are some used chemistry/glassware dealers that I'm sure you could pick up all you needed for penny's!
    Unfortunately there isn't any up here in scotland that I've found or I would be doing this just to see what it looked like :hip:
  12. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    This had been experimented around with before, mainly for the cooling benefits. If memory serves, something about a whirlpool naturally cools the water? There was a flurry of posts about this before, you should be able to find info in a search.
    As to the bubbles, if the outlet was far enough below the pool you won't get the bubbles into the stream. This is the type of thing that you would want to setup seperate of a computer to experiment with until you find the right setup.
  13. Kickn
    7 Oct 2003
    I think I might have spawned that previous thread which is why I remember it :D
    The problem was doing it under pressure if I remember - i may be wrong on that one - but any time you force a liquid through a small apature it forces the heat out into the surrounding area. This would cool the water but you would need need to transfer the heat away.
    I think something like this would be more for looks then performance.
