Build Advice ITX Again, but focus on weight and size
Discussion in 'Hardware' started by okenobi, 23 Aug 2012.
  1. okenobi
    okenobi What's a Dremel?
    3 Nov 2009
    I need to quote for a machine for an interesting application. It doesn't have to fully game, just serve media. BUT it does have to do Photoshop CS6 :D
    Also, it's gonna be used initially in the Italian Alps this season as my main TV/movies rig with my lovely Dell 23, rather than investing in an overpriced ultrabook. So portability is key.
    I need one SSD slot (thinking 128 will be enough, but maybe 256) and then room for a 3TB HDD for photos and media. If I can get two 3.5HDDs in - great. If not, so be it.
    Thinking the Asus Z77 board, with an i5, but can't decide whether to bother with Ivy Bridge, or just bang a Sandy Bridge in there. Did I remember correctly that they run cooler?
    Intended GPU is probably the same Sapphire Ultimate passive 6670 that's in my main rig here as it has DP, DVI and HDMI and it's ideal for media and light gaming.
    I will probably drive down there, so I can chuck it in the car, but on the off chance it has to fly anyway with me (or anybody else) it needs to be light and small.
    Quietness is preferable over speed, or power requirements (I have an R3 and Seasonic X here) but light and small has to be number one.
    Oh and if it could look nice, that'd be a plus.
    Thoughts?! :D
  2. dunx
    dunx ITX is where it's at !
    1 Sep 2010
  3. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    MAC mini? would be the easy option.
  4. okenobi
    3 Nov 2009
    Only one HDD from what I can make out, and no optical drive. Or am I going nuts?
    Dunx, that case looks interesting. What do you mean, no video? It has an expansion slot, no...?
  5. shah
    shah Minimodder
    29 Jan 2010
  6. okenobi
    3 Nov 2009
  7. shah
    shah Minimodder
    29 Jan 2010
  8. Jehla
    Jehla Minimodder
    8 Jan 2010
    The server model has two, but you can also get a kit to add a second drive to the other configurations. There isn't an inbuilt optical drive though.
  9. G12EG
    G12EG What's a Dremel?
    23 Aug 2012
    are you going to be over clocking?
    if not you could save a few ££ and get a h77 board
  10. dunx
    1 Sep 2010
    :duh: Linked item doesn't - I is stoopid....
    I have a Fractal server, I "had to" mod the drive cage to miss my GTX 480, drilled out two rivets, one saw cut and two new rivets means (only) a four bay drive cage +SSD, and acres of room, also needed a better SFX PSU for the silly GPU.
    But that was a couple of years back. The Elite is an easier "fix" IMHO
    Good luck with the project!
    dunx
    P.S. Sorry, old and confused :D
  11. okenobi
    3 Nov 2009
    Thanks for your help guys. Due to storage requirements, looks like I'm gonna be going small micro ATX instead. Just for the flexibility.
