Peripherals Keyboard Shortcuts
Discussion in 'Hardware' started by longweight, 22 Jul 2012.
  1. longweight
    7 May 2011
    Hi all,
    I love finding and using new keyboard shortcuts but I couldn't find a site that lists them for more than one program. I have started to list them out on my website, so far I have covered Windows and Chrome. Please have a look and post any that I have missed here! Or add them for other programs that people might find helpful!
    http://www.key-bored.net/keyboard-shortcuts/
    So far we have:
    Windows Shortcuts
    CTRL + ESC Open start menu
    ALT + TAB Switch between windows
    SHIFT + ALT + TAB Reverses through windows
    TAB Jump to next text box / item
    SHIFT + TAB Jumps back to the previous text box / tab
    SHIFT + F10 Performs the same action as right click
    CTRL + SHIFT + ESC Opens Windows task manager
    CTRL + A Select all
    CTRL + Z Undo
    CTRL + Y Redo
    CTRL + Q Quit application
    CTRL + W Close window / tab
    CTRL + R Refresh window
    CTRL + F Opens search box
    CTRL + C Copy
    CTRL + V Paste
    CTRL + X Cut
    CTRL + B Bold text
    CTRL + U Underline text
    CTRL + I Italicise text
    CTRL + N New window
    CTRL + O Open new file within program
    CTRL + F Opens find dialogue box
    CTRL + H Opens find and replace
    CTRL + TAB Cycles through program windows
    CTRL + SHIFT + TAB Reverse cycles through program windows.
    CTRL + L/R ARROW Jumps to end of next complete word
    WIN + E Opens a new Windows Explorer window
    WIN + F Starts the find in files dialog
    WIN + CTRL + F Starts the find a computer on a network dialog
    WIN + M Minimises all windows to desktop
    WIN + SHIFT + M Opens minimised windows
    WIN + R Opens Run dialog box
    WIN + F1 Opens Windows help window
    WIN + PAUSEBREAK Opens System Properties
    WIN + TAB Cycles through open windows on task bar
    WIN + SHIFT + TAB Reverse cycles through open windows on task bar
    WIN + D Shows desktop
    WIN + L/R ARROW Auto-fills current window to left or right hand side of screen
    WIN + UP ARROW Auto-fills current window to full screen
    WIN + DOWN ARROW Returns window to size previously set by user
    WIN + L Locks the machine
    CTRL + PRINTSCREEN Pasts entire display to clipboard
    CTRL + SHIFT + PRINTSCREEN Pastes the active window to clipboard
    CTRL + SHIFT + N New folder
    CTRL + LEFT CLICK Allows multiple selection of files out of sequence
    SHIFT + LEFT CLICK Allows multiple selection of files in sequence
    SHIFT + RIGHT CLICK Shows additional options for files
    Google Chrome Shortcuts
    CTRL + ENTER Adds www. and .com to any term entered in the onmi-box.
    CTRL + W Closes tab
    CTRL + SHIFT + T Opens closed tabs one at a time
    CTRL + T Opens news tab
    CTRL + N Opens new window
    CTRL + SHIFT + N Opens "incognito" window
    CTRL + 1 through 8 Jumps to the relevant tab
    CTRL + 9 Jumps to last tab
    CTRL + TAB Switches to next tab
    CTRL + SHIFT + TAB Switches to previous tab
    Backspace Previous webpage in tab history
    SHIFT + Backspace Next webpage in tab history
    ALT + E Opens wrench menu in a new tab
    CTRL + SHIFT + B Toggles the bookmarks bar on / off
    CTRL + H Opens history in new tab
    CTRL + J Opens downloads in a new tab
    SHIFT + ESC Opens Chrome's task manager
    F6 Highlights URL in address bar
    CTRL + L or ALT + D Highlights URL in address bar
    ALT + ENTER Opens URL entered in search box in a new tab.
  2. Somer_Himpson
    Somer_Himpson What's a Dremel?
    22 Jan 2010
    shift f3, cycle through case sizes in MS Word
  3. Somer_Himpson
    22 Jan 2010
    Windows key and D show desktop
    Windows key and pause/break ...windows system window + device manager
  4. longweight
    7 May 2011
    Case sizes?
  5. longweight
    7 May 2011
    How could I forget the WIN +D combo!
  6. Somer_Himpson
    22 Jan 2010
    upper case, lower case, capital letter, lower case etc
  7. Somer_Himpson
    22 Jan 2010
    WK+e - starts the Windows Explorer
    WK+f - starts the Find in Files dialog
    WK+Ctrl+f - starts the Find a Computer on the Network dialog
    WK+M - minimizes all the windows to clear the desktop
    WK+Shift+M - restores all the minimized windows
    WK+r - starts the Run dialog
    WK+F1 - starts Windows Help
    WK+Pause - starts System Properties
    Windows Key + TAB: Cycles through the open programs through the taskbar.
    If you have multiple windows open, hold down the windows key and tap the TAB key and the computer will cycle through your open windows. This is very similar to using ALT + TAB but without, what I like to call, the “mini window”.
    Alt F4...CLOSES CURRENT WINDOW
  8. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    Ctrl + left/right, flick through words when editing text
  9. Kronos
    Kronos Multimodder
    6 Nov 2009
    WK+L/R arrow web page takes up half the screen. I use that one a lot.
  10. longweight
    7 May 2011
    Good one! I use that lots too, it's hard to think of all the ones that you use in one go!
  11. allanparker
    allanparker What's a Dremel?
    15 Jul 2012
    Lot of shortcuts some available here :
    Windows Logo (Display or hide the Start menu)
    Windows Logo+BREAK (Display the System Properties dialog box)
    Windows Logo+D (Display the desktop)
    Windows Logo+M (Minimize all of the windows)
    Windows Logo+SHIFT+M (Restore the minimized windows)
    Windows Logo+E (Open My Computer)
    Windows Logo+F (Search for a file or a folder)
    CTRL+Windows Logo+F (Search for computers)
    Windows Logo+F1 (Display Windows Help)
    Windows Logo+ L (Lock the keyboard)
    Windows Logo+R (Open the Run dialog box)
    Windows Logo+U (Open Utility Manager)
  12. GMC
    GMC Minimodder
    26 Jun 2010
    You forgot ctrl+alt+delete. :p
    Ctrl +printscreen pastes the entire display to clipboard
    Ctrl+ shift + printscreen pastes the active window to clipboard
    Ctrl + arrows also advances you to next empty cell in that direction in excel also works for populated cells if the next cell is blank
    Substitute home or end for arrows in above and navigation is end to end horizontally
    Ctrl + shift + arrows/home/end as above but selects along the way. Also works by the word/line in msword and most notepad editors
    Ctrl + page up/down. Navigates pages in excel workbook. Add shift to select multiple sheets and make edits to all at once
    Win + L locks the machine
    Ctrl + f opens find dialogue
    Ctrl + h opens find and replace
    Alt + f4 closes active window
    Alt + ASCII codes (numlock on and four digit codes entered to numpad) generates symbols. IIRC 0160 is €
    Ctrl + alt + 4 (or e) gives €
    All the additions I can think of now without being on the machine. It's all in motor memory :rolleyes:
    G
    Sent from my HTC Desire HD using Xparent Red Tapatalk 2
  13. GMC
    GMC Minimodder
    26 Jun 2010
    Might not fit your purpose but ctrl plus leftclicks selects mutiple cells in excel. Handy if you want cells that are not next to each other.
  14. GMC
    GMC Minimodder
    26 Jun 2010
    Damn you longweight, I'll be thinking of these all night now!
    F2 opens rename for icons in windows or steps into edit a cell in excel
    Shift + delete in windows bypasses recycle bin
    longweight likes this.
  15. longweight
    7 May 2011
    Haha that has been happening to me all weekend! Some of yours are new to me and sound very helpful!
    I'm going to add more to the current list and then probably do lists for SFF keyboards such as the Poker, Pure and HHKB. Think that those will be helpful?
  16. GMC
    GMC Minimodder
    26 Jun 2010
    Would be interesting to see how many shortcuts require fn layers on pure, poker versus race and choc mini and the like.
  17. GMC
    GMC Minimodder
    26 Jun 2010
    F7 is spellchecker. Add shift for thesaurus in word, think it works in outlook too.
    F9 is calculate in excel. Handy if like me you have a lot of formulae on one file and a pos corporate laptop.
    F4 when you have selected a cell/range in excel cycles through absolute reference options for the selection. (I.e. adds the $ in)
  18. longweight
    7 May 2011
    True, I can never find a good clear list of the FN layer combinations just diagrams.
  19. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    does this count:
    Ctrl + Mouse wheel on windows back round to change Icon size?
  20. longweight
    7 May 2011
    It certainly does!
