Peripherals KVM's over network / ethernet
Discussion in 'Hardware' started by Springs, 18 Mar 2014.
  1. Springs
    Springs Boing boing
    29 Aug 2004
    Hi guys,
    I will be moving rooms in my house soon and looking to move my server into a different location.
    I'm looking to be able to keep remote visible access via a KVM. Just wondering if there are any decently priced (like sub £100) that would do the job?
    Mainly looking for one that works over a TCP/IP network or one that works point to point over a ethernet cable
    fuus likes this.
  2. narwen
    narwen narwen
    6 Aug 2010
    Best to say what operating systems you are using. Only then we can give the right info.
  3. Fruitloaf
    Fruitloaf Tinkerer
    5 Jun 2002
    I picked up an old KVM over IP box quite cheap on ebay for the same reason, maybe have a look there?
  4. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    if its a windows server, why not just use remote desktop?
  5. wolfticket
    19 Apr 2008
  6. Springs
    Springs Boing boing
    29 Aug 2004
    its a linux server that i use. i have remote ssh onto it but at times it's not come back up after a reboot and if its hidden away i need to be able to get onto the main screen to see why.
    i've been looking on ebay on and off but couldn't see anything there within the price range. haven't checked recently so i'll take another look.
  7. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Maybe an IPMI remote management card? I suspect you should be able to find something older like an eRIC on ebay or someplace for cheap enough. There are many others as well, but be careful as some of them appear to be like pci or pci-e but are not and only will work on certain motherboards proprietary ipmi slots.
  8. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    Ignore, doesn't work for video
