Modding Lap top screen for desktop mod.
Discussion in 'Modding' started by zachjowi, 7 Apr 2005.
  1. zachjowi
    zachjowi What's a Dremel?
    15 Jan 2005
    I had an old Compaq LTE 5400 laptop and I took it apart so all I have is the screen with the speakers and all the video, audio, and power connectors. I want to use this monitor as a regular monitor for my desktop by soldiering a 15 pin monitor connector. Does anyone have any ideas or resources as to how to do this?
  2. Zuke
    Zuke What's a Dremel?
    29 Mar 2005
    Old question, no good answer. You can only get it to VGA by first passing it through a LCD controller. You can find them at earthlcd.com. Good luck on finding one for less than $250
  3. Malvolio
    Malvolio .
    14 Dec 2003
    Do you still have the cd-rom from said lap-top? If so, I may be intersted in it...
    Otherwise, you're SOL on the monitor bit, you can't just connect it up to an RGB out on a video card.
  4. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    If you still have the controller, you may be able to find a pin-out for it, and connect it to a VGA output.
  5. zachjowi
    15 Jan 2005
    what does RGB stand for?
  6. Zuke
    29 Mar 2005
    RED - GREEN - BLUE
  7. FanatiK
    FanatiK What's a Dremel?
    25 May 2004
    OMG! You probably shouldnt tackle this project. :duh:
  8. Nexxo
    23 Oct 2001
    And please :search:
  9. zachjowi
    15 Jan 2005
    please help
  10. Hiren
    Hiren mind control Moderator
    15 May 2002
    Read
    As others have said in a nutshell - you'll most likely need a expensive controller card and it's generally not worth doing unless you can get one cheap.
  11. (spc)kuhnkejer
    (spc)kuhnkejer What's a Dremel?
    14 Feb 2005
    for the guy wanting an cd drive from a laptop i have an crw =dvd combo ill sell you and for the changing a lcd to an vga it cheaper to buy an lcd monitor from a store first you need to buy a controller and they cost a lot the make some kid of housing that can cost a but and for a 15 in lcd you can buy one cheaper then the cost of changing the laptop screen over to an vga but you could sell it on ebay people have been buying them for around 50 to 200 i sold an 17in one for 250 i would go the ebay way good luck
  12. Nexxo
    23 Oct 2001
    Ever hear of punctuation?
  13. McGuinness
    McGuinness Banned
    27 Nov 2004
    Or paragraphs?
  14. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    This question has come up several times in recent weeks, maybe it should be a sticky? :sigh:
  15. Go4t
    Go4t i
    13 Dec 2003
    there is a sticky but its in the electronics forum
    maybe if there was a way to have the sticky in the modding forum as well as the electronics forum it wouldnt happen so much
  16. XUntitled
    XUntitled What's a Dremel?
    6 Sep 2004
    More like years :wallbash: people need to learn to :search:
