Electronics LCD pinout
Discussion in 'Modding' started by glennd_05, 23 Jul 2004.
  1. glennd_05
    glennd_05 What's a Dremel?
    6 Nov 2003
    i have a toshiba LCD 640x480. it has four T6a40 chips and four T6a39 chips on the back, and 15 pinout connections. does anyone know where i can find a datasheet/pinout chart for this LCD
    thanks
    -glenn
  2. coorz
    coorz Miffed
    25 Apr 2003
    Have you tried Google :eyebrow: .
    Those IC's are column and row drivers.
    The panel itself has it's own partnumber, that's the one needed to find the pin-layout.
    Anyway 640x480 is VGA territory and needs a relatively expensive controller or the VFC method to drive.
  3. glennd_05
    6 Nov 2003
    yes i did try google, but to no avail
    the screen is a toshiba TLX-5171-C3M, i've tried their site but couldn't find it there either
    i have a controller card that i bought from Earth LCD's so, i'm fine there, but i have no way to connect them together.
    thanks
    -glenn
