Modding LED highlighted Keyboard (with all LEDs off switch NEW PHOTOS)
Discussion in 'Modding' started by David_Fitzy, 13 Jan 2004.
  1. David_Fitzy
    David_Fitzy I modded a keyboard once....
    8 Jan 2004
    I did this not too long ago but right now (13th Jan 2004 02:04) I can't get to sleep, so I thought I'd post this REALLY exciting post and increase my post count at the same time
    This Keyboard...
    Nice Translucent Blue cover to the side, me thinks my student budget can stretch to mod this :worried:
    Internals (No piccies of inside, not exciting anyway, just 2 lengths of wire and a mess of wires at the LEDs)
    Code:
         Res     |     LEDs     |
    5V--[===]----|-----(>|)-----|-------Gnd
    LED's where 5V 30mA
    PS/2 current limit is 100mA max
    status LEDs (Caps, Num Scroll) took 25mA total (measured)
    So 100-25=75mA spare
    Res = 5V/75mA = 66 Ohm
    Each LED runs on 22mA
    (don't quote me I can't actually remember presisely :confused: )
    Result
    [​IMG] [​IMG]
    and after I turned the LEDs upside down to diffuse the light a bit
    That's all folks
    Sleep Beckons now....
  2. Jpantoga
    Jpantoga What's a Dremel?
    12 Jan 2004
    wow, really nice
  3. daydreamingknight
    daydreamingknight What's a Dremel?
    9 Jun 2002
    Agreed. looks very nice...give it to me? :D
    DDK
  4. David_Fitzy
    8 Jan 2004
    Glad you like it :D
    I still need to replace the green staus LEDs (might do that this weekend)
  5. Atomic
    Atomic Gerwaff
    6 May 2002
    I spy a Genius Keyboard, nice things actually. I use the same one as that here at work, the mute/volume keys are a god send! Muting my music when someone comes in to annoy me/ask a question)
    You gonna do the same with the top bit? (bit with the WWW controls on) Might involve a bit of cutting but would look cool.
  6. warrmr
    warrmr What's a Dremel?
    5 Nov 2003
    how about have a LED flash each time you press a key
  7. richman
    richman What's a Dremel?
    17 Sep 2003
    good work m8, how about getting a bit of led string and putting it under your keys to get them lit up.
    Richman
  8. David_Fitzy
    8 Jan 2004
    There looks like a 1-2mm gap under the plastic, I've seen people talking about light panels in other threads I think like EL wire, could I use this can I cut it to size? Can I cut holes in it?
  9. Fubar
    Fubar What's a Dremel?
    7 Oct 2003
    how are you powering the leds?
  10. zachypoo
    zachypoo What's a Dremel?
    12 Jan 2004
    It comes through the PS/2 port. If you read he said he had 100mA (thats the amount of power it gives)to use so he tapped off the power line that comes through.
    MrDT likes this.
  11. death_star
    death_star What's a Dremel?
    14 Jul 2003
    Do ya think I can do this to the two tranclucent peices of plastic on the logitec wireless duo? I dont wanna take apart a $90+ keyboard though.
  12. David_Fitzy
    8 Jan 2004
    Yeah, my LED's run off the PS/2 power the keyboard itself takes 25mA which left me 75mA to play with. So any more modifcations will mean an external power source. I do need a switch though this mod is in my bedroom and VERY bright even with the computer shut down (I'm going to try a transistor switch off the clock line but I need better simulation software first)
    As for the $90+ keyboard if you do try any mods take it apart VERY CAREFULLY and I doubt you'll have a problem, powering mods won't be such a problem because power is coming from batteries you can draw a fair amount of current (depends on the battery life you want) unlike my wired keyboard where the motherboard has a restriction (called a fuse:))
  13. David_Fitzy
    8 Jan 2004
    UPDATE: I've finished my degree :wallbash: and i'm starting to think about modding again :D (I've got a case project in design atm) but in the mean time I've finally added a switch to switch off the all LEDs (even the status LEDs) as whenever my pc powers down which ever status lights where left on stay on)(my ststus LEDs are still green btw :rolleyes: )
    I'm only posting as the ability to switch off status LEDs may be of interest to some people
    the new circuit:
    Code:
       Switch
          o
    5V-o<              ,-----(>|)-----.
               Res     |  BLUE LEDs   |
          o-,-[===]----|-----(>|)-----|-------Gnd
            |                                   Microprocessor
            |                                 _____________________
            |----------------(>|)-----------o|NumLock LED port     |
            |----------------(>|)-----------o|CapsLock LED port    |
            '----------------(>|)-----------o|ScrollLock LED port  |
    Generally micros cannot provide enough current to light a LED but can sink enough current to ground to light them (Logic works in reverse to switch on the LED the micro sends 0 (off) command to the port) this is the cheapest way of doing this so I'd suspect this exact solution would work for every keyboard.
    So to have a switch to switch all status LEDs offl:
    1. cut the 5V line to each of the LEDs
    2. solder in some wire to each LED anode
    3. solder the wire through a switch back to the 5V supply
    PS. Sorry no piccies posting on bit-tech was an after-thought
  14. mattthegamer463
    26 Nov 2004
    sounds like a plan.
  15. David_Fitzy
    8 Jan 2004
    PHOTOS
    I beggared up one of the solder joints :duh: so I had to open the case and I took the oportunity to take some piccies with my amazing(ly rubbish) camera :blush:
    The Installed Switch
    Here's the jumble of wires to make up the blue LEDs
    Here you can see the wire to join all the LED anodes together and the cut 5V rail (near the left end of the green wire)
    Here's the connections to the control board you can see I've cut two of the links (5V rail) and used the remaining bits to solder to
    Red Wire - Connects to Blue LEDs
    Green Wire - Connects 5V from PS2 to switch
    Short Black wire (bottom left) - connects switch to LED 5V rail
    Long Black wire (across top) - connects blue LEDs to ground (this was the dry joint)
