when i was searching the internet, i found that some lian li pc70s have a little rectangular plasic sheet around the pwer/reset buttons, some don't... what's up with this? i like lian li because of it's clean look and this plastic on the front kinda destroys that if ne1 knows where i could get the cases w/out this thing please let me know... thx crazylord (the new german forum member )
the pc71 i got 4 weeks ago from newegg.com doesnt have the fake carbon fibre around the buttons .... i dunno bout the 70's though ...
rev1 cases = plastic bezel done up to look like alu (what i have) rev2 cases = no bezel but crap plastic buttons neuro = modded bt i'm gonna have to do something with mine and not cfibre cause i don't particularily think it'll fit mine so i gonna fiddle with the spare sidepanel i got cause i want new vandal resistant buttons too so ask if you can get a rev2 if poss ... or see it in person first !
neuro m8 is that a white led? if it is did you have to put a resistor on it? and where can i get them from? maplin or ??? Later AW3K
with the rev1 cases, can you take the plastic bezel of ? could you possible build a new one with alu? with rev2 cases, can you replace the "crap plastic buttons"? i've seen replaced power buttons, but what about the reset button? thanx for all the quick replies
rev1: not unless u want a lot too many holes and not working buttons :/ i'm planning to build a new one... but maybe not for a couple of months cause of exams and stuff rev2: you should be able to they both use momentary actions i believe
the new rev2 pc-60's also have a blow hole in top of case. I got mine a few weeks ago, wasnt expecting that.
i think the version 2 looks better... that bezel thing looks cr@p and ruins the look. the only thing i hate about my verion 2 (w/out the top blowhole) is the fake carbon fibre on the top and bottom of the removable front panel. ruins the whole dam thing.
http://www.so-trickcomputers.com/Me...Store_Code=S&Product_Code=LL&Category_Code=LL You might drop him an email or call him to make sure thats exactly how ya want it, if it isnt, i'm sure he can get what ya want.
thats just an extreme brightness blue LED - taken with a dodgy web cam :-/ i think maplin do white LEDs, not sure how bright they are tho.
