Linux linux wont install
Discussion in 'Software' started by n0d4x, 16 Aug 2007.
  1. n0d4x
    n0d4x What's a Dremel?
    1 Feb 2007
    I have a very old 99' dell p3 with 640mb of ram
    I want to install ubuntu but I put int he disk and boot it wont I went in bios changed it to boot cd drive first
    it just doesnt want to install
    any ideas?
    the disk works I just tested it
  2. n0d4x
    1 Feb 2007
    is the newest ubuntu btw
  3. n0d4x
    1 Feb 2007
    anyone? xp wont install either
    man windows 98 BLOWS
  4. Drachnem
    Drachnem Minimodder
    15 Nov 2003
    Make sure you burned the disc right.
  5. n0d4x
    1 Feb 2007
    not burned disk
    both work too the xp is a legit xp copy and the ubuntu copy is one they sent me *shrug*
  6. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    how far do you get? can you get to the first screen, or do you just get the "no boot disk" message?
  7. n0d4x
    1 Feb 2007
    I dont get ANYTHING at all boots up like normal
  8. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Does the CD drive work? its getting on a bit wouldn't be surprised if parts if it had started to fail.
  9. n0d4x
    1 Feb 2007
    nope cd drive works great
    this is really pissing me off im going to slap another drive in just incase though
  10. Fophillips
    Fophillips What's a Dremel?
    9 Oct 2006
    try the alternate install disc
  11. n0d4x
    1 Feb 2007
    new cd drive new disk
    I tried a xp disk a win2k disk a xubuntu disk and a ubuntu disk
    not working someone told me they had this problem and they wiped the hardrive and it installed but I dont want to wipe off the old os if I cant install anything else!
  12. DougEdey
    5 Jul 2005
    try disabling the hard drive in BIOS, installs should still detect it.
  13. n0d4x
    1 Feb 2007
    im going to try that later today
  14. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    Have you told it to boot from the optical drive before the hard disk?
    Moriquendi
  15. n0d4x
    1 Feb 2007
    yeah I have I tried disabling the hardrive in the bios didnt work
    I think the only way to fix it is to wipe the hardrive or get a new hardrive which I need so I will wait till I can get a bigger hardrive then ill put linux on it
  16. notatoad
    25 Jun 2004
    if disabling the hdd in bios didn't fix it, a new hard drive won't fix it either. is the cd drive the master of it's channel?
