Graphics Low Profile GPU for 4k Display
Discussion in 'Hardware' started by Pookie, 3 Dec 2015.
  1. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
  2. MrGumby
    MrGumby CPC 464 User
    27 Apr 2009
    Aren't the Maxwell family of gpus hdmi 2.0? perhaps a gtx750?
  3. MrGumby
    27 Apr 2009
    A quick google and check around and there doesn't seem to be any low profile HDMI 2.0 graphics cards around sorry
  4. Pookie
    4 May 2010
    Thanks for looking, my google fu is normally pretty good but I cant see one either :sigh:
  5. MSHunter
    MSHunter Minimodder
    24 Apr 2009
  6. ChrisHowell
    ChrisHowell What's a Dremel?
    29 Aug 2015
    Since you're not playing games, you could consider looking at the latest Skylake Motherboards and just not bothering with the GFX card. They might give you what you want.
    I've been looking at the latest offerings from Asus. This ITX mobo below says: "Supports HDMI with max. resolution 4096 x 2160 @ 24 Hz ". Not quite 60Hz, but there you go.
    https://www.asus.com/uk/Motherboards/Z170I-PRO-GAMING/specifications/
    Also, if you are in the midst of making some purchasing decisions, you might consider if HDMI 2.0 or Display Port will be the dominant connector of choice in the near future ( I don't know the answer to that, but might be worth holding out before you buy) - otherwise you might continue to struggle with what you're looking for.
  7. Pookie
    4 May 2010
    That looks like a good plan, how will I know if the Panasonic will bind the 2 ports so to speak?
