Scratch Build – In Progress LuZmA Mod 2010 Ken Block
Discussion in 'Project Logs' started by LuZmA, 9 Aug 2010.
  1. LuZmA
    LuZmA What's a Dremel?
    9 Aug 2010
    Hello & Welcome to my worklog :)
    A few months ago i found a RC car on my garage and i thought i could do something with it so i started this project
    SPONSORS
    At the moment im looking for sponsors because i want to do some new projects on 2011
    Well, it is the rc car, so i tried to figure out how to get an atom board into the car and be able to play with it
    here you got the equipment for the lights
    The car cover is air brushed with the ken block's car colour scheme
    Here you can see the steel base and some other components
    here you can see the finished bodywork
    :dremel: :dremel: It´s Dremel Time!! :dremel: :dremel:
    As you can see the lights are very powerful
    The steel plate that acts as the motherboard tray
    this is the acrylic window for the windshield
    And the led display with the connections
    :rock: The end , thanks for watching :) :rock:
  2. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
    No es el primero que veo así (incluso español) pero está muy bien.
    Althoug it's not the first mod in this way, it's very well done. Did you use templates or stickers for painting the cover?
  3. LuZmA
    9 Aug 2010
    Gracias, Kumo, esto lo hice en 2 meses y con 17 años, para ser mi primer mod mola.
    Thx kumo, this is my first mod and I have 17 years :thumb:
  4. LuZmA
    9 Aug 2010
    Yes, I used templates :)
  5. Anubus
    Anubus Minimodder
    7 Jul 2008
    I always enjoy R/C mods. :thumb:
  6. LuZmA
    9 Aug 2010
    Thx :)
    The case for the next project will be a lian li p 80
