Apple Macbook pro questions
Discussion in 'Software' started by The_Crazy_Canadian, 29 Nov 2006.
  1. The_Crazy_Canadian
    The_Crazy_Canadian What's a Dremel?
    12 Jul 2006
    I've got my new macbook pro and i'm loving it the only concern i have is that when i turn it on or when it wakes from sleep the disk drive sounds like it's ejecting a disk even when there's nothing in the drive. my question is, is this normal. it's the new MBP with dl superdrive if that helps
  2. solar
    solar What's a Dremel?
    6 Mar 2004
    Don't worry, all Macs do that. It's just checking whether or not there's a disc in the drive.
  3. Firehed
    15 Feb 2004
    In fact, most slot-load drives do that regardless of the rest of the system.
  4. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    yep, normal. it's a noisy little bugger, though.
    fun to watch, stick a CD in the drive but not far enough for it to suck it in, then put mac to sleep and wake - watch it push the disc out!
  5. unrealhippie
    unrealhippie What's a Dremel?
    24 Jul 2004
    Hours of fun!
  6. Fod
    26 Aug 2004
    well, maybe seconds of idle amusement. but your comment got the syntax partially correct. were it not for the faulty semantics i would have been forced into adulating agreement!
  7. The_Crazy_Canadian
    12 Jul 2006
    I guess i was just being paranoid but it's better to ask then have a faulty optical drive. Thanks for all your help
  8. idnzor
    idnzor What's a Dremel?
    6 Dec 2006
    Cool, I thought it was only mine that did this as well, i find the sound that plays on bootup pretty annoying as well, is there anyway to disable it?
  9. Seth
    Seth What's a Dremel?
    14 Mar 2002
    ^ you turn your mac off? why? just close the lid.
  10. 1e8o
    1e8o What's a Dremel?
    13 Oct 2005
    Just leave it on :D :naughty:
  11. Firehed
    15 Feb 2004
    Nope, it's hard-coded into the boot :( It's distorted to hell on the left speaker of my MBP as well, even though both speakers are fine playing music (this isn't uncommon, to my understanding).
    I'd stick with standby... much quicker, and a lot more reliable than anything Windows has ever offered in my experience.
  12. cderalow
    cderalow bondage master!
    23 Jan 2002
    if your system alert volume is low, boot sound is at the same volume level
