Guide Make your own USB LCD controller!
Discussion in 'Modding' started by ch424, 23 Jun 2006.
  1. One~Zero
    One~Zero What's a Dremel?
    9 Sep 2004
    RB6 is a control pin for the LCD.....:eyebrow:
    RB7 is already tied to the backlight with Q1 and R2 (See first page, first post)
  2. simon_stz
    simon_stz What's a Dremel?
    28 Mar 2007
    Sorry guys, I read the wrong line. The correct pin for backlight is RB7
  3. DocPL
    DocPL What's a Dremel?
    6 Sep 2007
    Wayneeboy could you tell me what kind of component is marked E$ on your schematic and what parameters it has.
    Thanks in advance.
  4. Wayneeboy
    Wayneeboy What's a Dremel?
    5 Mar 2007
    its a 100uf cap.
    ive done a different board however Ive got a problem
    with the contrast I cant adjust it in the LCD Smartie,
    could it be the transistor used ???
    this is a modified version of the above with a header
    for the usb connection
  5. gsila
    gsila What's a Dremel?
    22 Jun 2006
  6. Project_Nightmare
    Project_Nightmare What's a Dremel?
    14 Oct 2006
    To get the image to size correct was easier said than done. Whenever I saved the image in the correct dpi, it reverted back to the old dpi. :eyebrow: I solved this by changing the format to .png :dremel:
  7. Viscera
    Viscera What's a Dremel?
    17 Sep 2007
    Hi all,
    I'm going to be making this project, it looks simple enough for my first kind of project like this. First off could I get a list of parts from either Latvian3Dman, or Wayneeboy.
    Both are a great reduced version of the original project, no offence ch424 you did an awesome job puttin this all together, but i have no use for a buzzer or rotary switch. :)
    Also, Since im using Vista 64bit, would I be better off with the HID model, or the other which emulates a serial port. Or does the vista 64 driver that was posted before work fine with the serial port interface, I'm not familiar with hacking the software to do the serial port emulation.
    Finally, I dont have a programmer, could someone link me to a place to buy one on the cheep (US$30 or less) or a great diagram to make one myself.
    Many thanks guys
  8. Wayneeboy
    5 Mar 2007
  9. Viscera
    17 Sep 2007
    Thanks
    I might go with building a JDM programmer, as I'll only be programming one PIC, and I dont think I'll be repeating doing this again.
    Also, Wayneeboy, would it be possible to get a component list for the PCB you have posted above? I think im going to use your re-design
    Thankyou
  10. Wayneeboy
    5 Mar 2007
  11. Scorpia
    Scorpia What's a Dremel?
    17 Jul 2006
    not sure whats the go with up-files sending me to freindlyfiles. but there was some reports of there download software being spyware.
    a quick search found this url on how to download the file without loading there software.
    http://visualguides.nfshost.com/you-cannot-use-friendlyfilesnet-with-firefox/
    i couldnt do a "viewsource" in IE so i saved the HTML page and then did a search in the file. found lcd.rar easy enough.
    any chance of me hosting the file for ya?
    Scorpia
  12. ers35
    ers35 What's a Dremel?
    20 Sep 2007
    I am the one who wrote the article Scorpia was referring to, and you cannot post the direct link as it is dynamically generated for your ip address when you open the page. You must post the normal link and have each person view the source of the page every time they want to download.
  13. Wayneeboy
    5 Mar 2007
    link changed
  14. DSquareD
    DSquareD What's a Dremel?
    24 Nov 2005
    ok so ive read this whole thread now and i am so lost...i would love to put an lcd in my rig wen i get around to modding it but i have absolutely no idea what any of this means at all...the pictures and print outs and circuitries and all of that in the beginning of the thread all mean absolutely nothing to me...can some one explain it to me or guide to where i can learn wot this all is?
  15. veenone
    veenone What's a Dremel?
    21 Aug 2007
    Hi all, I've been following this thread for a while now. I'm really interested with latvian3dman circuit because it's so compact and really neat. for Latvian3dMan, can I get the picture of the circuit so I can follow your design? And with its part list of course ;) It's still using ch424's firmware isn't it?
  16. Viscera
    17 Sep 2007
    Hello again
    I have just recieved the PIC chip today, and tried to program it, and it gets an error when it try's to program it, however it can read from the chip fine
    Im using winpic800 on Vista 32
    I made this programmer here http://www.foxdelta.com/products/art2003.htm
    Im wondering what i did wrong, this is my first project ever so go easy on me :)
    http://hosted.intarweb.info/dan/DSC00028.JPG
    http://hosted.intarweb.info/dan/DSC00030.JPG
    http://hosted.intarweb.info/dan/DSC00031.JPG
    http://hosted.intarweb.info/dan/DSC00032.JPG
    http://hosted.intarweb.info/dan/DSC00033.JPG
    In the second last picture, i bridged the connectors by soldering a piece of wire to each then to the point.
  17. Scorpia
    17 Jul 2006
    as far as i know you cant use the art2003 programmer because it ties up one of the pins the software needs to run the LCD.
    will have to get a different programmer.
    Scorpia
  18. elektronix
    elektronix What's a Dremel?
    27 Sep 2007
    Hallo,
    you have changed the Pin of the plug.
    The red wire is on your picture on Pin 14-21!!
    The Pin of the plug ( from the schematic ) is from the front !!!
    from behind:
    14 15 16 17 18 19 20 21 22 23 24 25
    1 2 3 4 5 6 7 8 9 10 11 12 13
    best regards from Germany
  19. Scorpia
    17 Jul 2006
  20. elektronix
    27 Sep 2007
    The canged pin on Plug is for Viscera!
    He has changed the Pin of the plug.
    The red wire is on the picture on Pin 14-21!!
