Guide Make your own USB LCD controller!
Discussion in 'Modding' started by ch424, 23 Jun 2006.
  1. Erik
    Erik What's a Dremel?
    8 Oct 2007
    Buttons...
    Does anyone have a schematic or a pcb picture using buttons instead of the rotary encoder? I just need to see how to connect the buttons...
    Thanks
  2. ch424
    ch424 Design Warrior
    26 May 2004
    Good job Erik! There's no difference for the buttons - you use the common ground to one pin on each button, then one of the resistors to one button each.
    ch424
  3. Erik
    8 Oct 2007
    CH424...
    I might be being a little dense here...I've wired them up the way you say (I think)...LCD Smartie not seing the buttons pressed...any suggestions? Basically, I think I need pictures...
  4. Longbow
    Longbow What's a Dremel?
    9 Oct 2007
    Who's selling these controllers pre-built (with the rotary encoder), or at least with all the components?
    Thanks.
  5. derbaum
    derbaum What's a Dremel?
    11 Apr 2004
    i want to build this with 2x16vfd, as far is i could read it out this thread, the power consumption of a vfd could course trouble? would an external pwr supply, for example my normal atx psu, fix this prob ?
  6. One~Zero
    One~Zero What's a Dremel?
    9 Sep 2004
    Yes. Just use the ATX to power the VFD and the USB to power the rest of the circuit. Make sure all the grounds are tied together though.
  7. Erik
    8 Oct 2007
    Aidlover, not sure if you got an answer, I did not see one so far. I was getting the exact smae error, once I set the fuses in the programmer correctly it worked fine. This is the change I had to make: oscillator setting to HS+PLL HS-USB
    Hope that helps,
    Erik
  8. Erik
    8 Oct 2007
    Latvian3Dman,
    I had the same issue, this is from the plugin page: You will also want to change your refresh interval (on Screens page) and dll check interval (on Misc tab) rate as low as possible (12 is perfect, 25 is v.good, 75 fair...).
    Once I made the changes, it was smooth...very nice.
    Hope this helps.
    Erik
  9. Latvian3Dman
    Latvian3Dman What's a Dremel?
    25 May 2007
    Thank you for hints/suggestions, Erik! I will try that. :cooldude:
  10. Ismael
    Ismael What's a Dremel?
    10 Oct 2007
    Hi!!
    Very good project!
    Next monday I will start to build the project and post some photos.
    The source-code is avaiable for custom modifications?
    []'s
    Ismael
  11. Erik
    8 Oct 2007
    Not a problem. I noticed earlier that you were including buttons on yours, did you manage to get them working? If so how did you connect them? Were they momentary switches, normally open? I am having a hard time getting the buttons to work.
    Thanks,
    Erik
  12. Erik
    8 Oct 2007
    After Playing around with the wiring, I managed to get the buttons to work. Just a silly mistake...
    Thanks ch424...Awesome project. Would it be possible to get the source code, I would like to add a few more buttons. If possible could you please email it to
    erikjjenkins##at##gmail.com--without the #s.
    Thanks.
  13. Project_Nightmare
    Project_Nightmare What's a Dremel?
    14 Oct 2006
    Capacitor Values
    I bought some of the parts for some of my various projects (some of the parts I plan to use on this projects), and I noticed something on the package of my crystal :eyebrow: Looking at the crystal package, it said to use the capacitor value of 20pF :jawdrop: , instead of the values you posted ch424 of 22pF :waah: . Since I didn't buy the 20pF capacitors, would the 22pF capacitors work on all the crystals that have the rated capacitor value of 20pF:confused:
  14. Project_Nightmare
    14 Oct 2006
    Oops, I can't find how to delete this post that I wrote this text in. Plus the post above it is perfectly fine
  15. Stonewall78
    Stonewall78 What's a Dremel?
    21 Oct 2005
    The 20pF caps should be fine, really with the tolerance errors they will be very close. At worst you may have the off start up problem. I think for most crystals I have seen anything in the 18-22pf range work fine.
  16. Project_Nightmare
    14 Oct 2006
    BTW I have 22pF caps, not the crystal's rated 20pF caps:nono:. I read something about that in the PIC's manual, it mentioned that higher caps have alonger start-up time but are more stable than lesser values when used on a crystal:dremel:. Hopefully I wouldn't have any problems:sigh:....Hopefully:rolleyes:
  17. Erik
    8 Oct 2007
    ICSP
    I have never used the ICSP function on my programmer. What pins should I connect the leads to from my programmer, and is there anything else I need to connect or disconnect to program this in circuit.
    My programmer is marked with the following connections for ICSP:
    GND - Yellow Wire (ground)
    VCC - Black Wire (Positive power)
    CLK - White Wire (PIN 27 - RB6)
    DAT - Green Wire (PIN 28 - RB7)
    VPP - Red Wire (PIN 1 - MCLR)
    The information between the () are my assumptions.
    Works fine now, I have to disconnect pin 1 from the circuit to use the ICSP.
  18. Erik
    8 Oct 2007
    button = double
    Changed the encoder in the source to buttons, it is now the following:
    Button "A" still RC2 - Pin 13
    Button "B" still RC1 - Pin 12
    Button "S" still RC0 - Pin 11
    Added:
    Button "C" to RC7 - Pin 17
    Button "D" to RC6 - Pin 18
    I added a toggle switch between Pin 1 on the PIC and the power so I can now hit the switch...reprogram the PIC and hit the switch again to test it out.
    Erik
  19. Erik
    8 Oct 2007
    Latest Version board
    I plan on using the toner method to make a few PCBs for this, does anyone have a Hi-res image of the latest board that I can use?
    Thanks a lot,
    Erik
  20. Wayneeboy
    Wayneeboy What's a Dremel?
    5 Mar 2007
    why dont you download some pcb cad software and make your own.
