Guide Make your own USB LCD controller!
Discussion in 'Modding' started by ch424, 23 Jun 2006.
  1. Erik
    Erik What's a Dremel?
    8 Oct 2007
    I can do that, but if it has already been done, why recreate the wheel.
    Thanks,
    Erik
  2. Wayneeboy
    Wayneeboy What's a Dremel?
    5 Mar 2007
    i suppose but most, if not all only have the 3 pins for the encoder / switches
  3. Erik
    8 Oct 2007
    Nevermind, I'll do it myself.
    Thanks,
    Erik
  4. HYTEC
    HYTEC What's a Dremel?
    1 Jul 2007
    Just wondering if anyone checked this out. anyone see any errors?
  5. Ismael
    Ismael What's a Dremel?
    10 Oct 2007
    Hi!!
    The project is working fine here!!!! I will post some pictures later.
    Just three doubts:
    - Can I control 16x2 LCDs?
    - How activate the buzzer using LCDSmartie?
    - Can I control the contrast by software?
    []'s
    Ismael
  6. gsila
    gsila What's a Dremel?
    22 Jun 2006
    hello
    can anyone check my circuit for any errors please?
  7. Wayneeboy
    5 Mar 2007
    If the schematic is right there is no reason
    why it should not work. There is a wire link
    that you can replace with a track
  8. gsila
    22 Jun 2006
    yes i know for that wirelink but is made for quick off backlight
    Im not 100% sure that the PCB is O.K.
  9. gsila
    22 Jun 2006
    anyone ????????????????:confused::confused::confused:
  10. Ismael
    10 Oct 2007
    Hi!
    Your circuit is ok!
    And a information: the circuito is plug and play with 16x2 and 20x2 LCD!
    I test today!
    []'s
    Ismael
  11. gsila
    22 Jun 2006
    is plug and play also for 4x20
  12. One~Zero
    One~Zero What's a Dremel?
    9 Sep 2004
    yes.
  13. gsila
    22 Jun 2006
    great:rock::rock::rock::thumb:
  14. derbaum
    derbaum What's a Dremel?
    11 Apr 2004
    i can not get a bc184L trans. can i use another bc trans. instead ? if yes ... bc in general or a special one ?
    edit: maybe the 547 is right ?
    thx
  15. gsila
    22 Jun 2006
    i will be using BC548B
  16. Ismael
    10 Oct 2007
    Hi!!
    My LCD working!
    I am having problems with the encoder. I receive any key when I pressed the buttons. I test with Hyper Terminal too and anything.
    Anyone can help?
    Thanks,
    Ismael
  17. Wayneeboy
    5 Mar 2007
    you have not soldered the legs of the chip associated with the encoder
  18. Ismael
    10 Oct 2007
    Hahahahaha
    Sorry for this... :(
    I sold just the pins to test USB and LCD. And forget to solder others.
    Thank you and sorry!!
    []'s
    Ismael
  19. DocPL
    DocPL What's a Dremel?
    6 Sep 2007
    Hi all
    Well today I soldered my USB LCD controller according to Waneeboy diagram (see below) I have just one problem there is no way to turn backlight on. Do you have anny suggestions? Transistor maybe ?
    EDIT.
    I just resoldered transistor - just turned it around for 180 degrees - I have backlight on now but I can't turn it off with Lcd Smartie ( I was able to do it when LCD was hooked to LCD port)
  20. bubsterboo
    bubsterboo What's a Dremel?
    24 Jan 2006
    The link is down, Could someone please be kind enough to re-upload the compiled code for my 18f4550?
    Thank you.
