Guide Make your own USB LCD controller!
Discussion in 'Modding' started by ch424, 23 Jun 2006.
  1. gazman321
    gazman321 What's a Dremel?
    6 Jul 2009
    Yes they are the ones(big bulky green ones shown on page 2), Thanks for the info Wayneeboy :thumb:
  2. Scorpia
    Scorpia What's a Dremel?
    17 Jul 2006
    ah yes that was my board with the green caps.
    please ignore them and just get the standard types. they were some spares i had laying around.
    Im pretty sure i replaced them not long after that
  3. wally88
    wally88 What's a Dremel?
    7 Jun 2009
    Hi can someone send me the source code of 3 button version for 2550?
    Please, my email: adrian07b@gmail.com thanks!!
    EDIT: Scorpia, can send me the .hex file of 2550 3 buttons with a welcome message? just a "welcome" xD please
    thanks!
  4. Pzymen
    Pzymen What's a Dremel?
    3 Aug 2009
    If it's possible I would also like the .hex file for pic18f2550 3 buttons and welcome message.
    Email: pzymen @ hotmail.com
    Thanks
  5. gazman321
    6 Jul 2009
    Hi
    Could someone please send the hex file for the button version, 18F2550 Pic, Please.
    Also how would I connect the buttons instead of the rotary encoder ?
    Thanks
    gazman321@yahoo.co.uk
  6. gazman321
    6 Jul 2009
    urgent help needed please
    hi every one have made a lcd2usb, but am having major trouble it detected fine in windows xp, using lcd smartie set it to the right com port and using serial matrix orbital, lcd lights up but no txt is diplayed just 1 line of little boxes, if i close the lcdsmartie down lcd shuts down as well. but still no txt. please help dont know where to start looking.
  7. Wayneeboy
    Wayneeboy What's a Dremel?
    5 Mar 2007
    it seems it is working but no data is being sent to the lcd just have a play with lcdsmartie. have you downloaded any plugins for it ??
  8. gazman321
    6 Jul 2009
    Thanks Wayneeboy, I got it working, I had to shorten the cables betwwen the LCD and Controller, Now I have it working is GREAT !!!! Thanks for all youe help.
    Waynneboy, do you have the eagle files/layout for the pcb and parts list for the board you designed (on page 18, the one with no buzzer), that i could have a copy of ? I would love to make another board !
    Many Thanks
  9. Rorix
    Rorix What's a Dremel?
    21 Aug 2009
    hi there , trying to build this awsome proyect
    already got it on a breadboard , my pc assings a port
    everything seems to be working fine but then when i open lcdsmartie
    i get this "failed to open device : DLL Initialize error : Matrix.dll Exception .."
    using 4mhz , 22pf , and 220nf cap/crystal
    any thoughts?
  10. gazman321
    6 Jul 2009
    I get "failed to open device : DLL Initialize error : Matrix.dll Exception .." if I have smartie set to the wrong com port
  11. Rorix
    21 Aug 2009
    mmm my pic gives me a comm5 , so i assing it to lcd smartie
    i also moved serial port thing on bios , and set it to EEP
    read somewhere it makes some things easier
    anything else i need to set? maybe reinstall drivers or something
    try vista driver?
    currently using win xp sp3
  12. gazman321
    6 Jul 2009
    you could always try downloading ane unzipping smartie again, I did after having this error. Also have device manager open, when you plug you lcd in, then you will be able to double check com port.
    What drivers did you install ?
    Do you have your lcd on serial or usb ?
  13. Rorix
    21 Aug 2009
    ima try reinstalling driver and smartie , it could work :thumb:
    installed driver on first page , for win xp
    umm its on usb with my pic18f2550
    edit: same problem reinstalled smartie and driver
    ima try with another lcd , maybe mine is dead
    even tho it shows rows when i turn it on
  14. gazman321
    6 Jul 2009
    Yeah, Maybe a dead screen, I do have one, 16x2, that when connected, shows a row of blocks on line one but it is like smartie cannot find the screen and shows that error
  15. Rorix
    21 Aug 2009
    yah actually my lcd is 16x2
    ima try with another one
    also ima write a lil code to test it
    to show something with a pic76f84
    thanks :D
    edit it was my lcd got itworking now
    thanks for the help and theproyect
  16. Rorix
    21 Aug 2009
    sry for double post but can someone send me the C code , so i can add more buttons plz?
    my mail elxilote@gmail.com
  17. thaimin
    thaimin What's a Dremel?
    24 Apr 2009
    Funny so many people having a problem with the COM port recently, because I kinda got frustrated with COM ports changing and stuff like that. I made a special driver for LCD Smartie that finds the right port by itself. It looks for a device in Windows with a matching VID and PID (vendor and product ID) and binds to that. I made it in particular for the VID and PID of my version of USB2LCD, but it could be easily adapter to look for the Microchip port (VID=04D8, PID=000A). It also produces slightly better error messages when something does go wrong (like the "COM port is in probably in use" instead of just a generic "Cannot connect").
    If you want to try and make a DLL display driver for your display, the code can be found at http://www.coderforlife.com/projects/lcd/lcd-smartie-display.zip
    It is a Visual C++ Project. You only have to change one line to change which display it looks for. The display must support the Matrix DLL normally.
  18. dCrypt
    dCrypt What's a Dremel?
    6 Sep 2009
    Hi,
    I have been looking or a solution like this for months, I am very surprised it was available for years!!!
    I have a really tiny eadip204b 4x20 display, based on KS0073 controller. I was wondering whether this circuit will be compatible or not, as KS0073 should be hitachi-compatible.
    Thanks.
  19. electronistu
    electronistu What's a Dremel?
    9 Sep 2009
    I have started this project myself. Thaks to everyone that posted.
    I have some problems with config bits of PIC18F2550.
    I am using winpic software, is anyone able to give me a screenshot of his right settings?
    I have used only PIC12F629 until now with doesn't require any settings regarding config bits.
    I have read some posts, also loked at required programmer config posted by ch424 at the begining at this thread, can't figure out.
  20. gazman321
    6 Jul 2009
    Hi
    Could someone please advise me on how to solder a usb cable straight to the pcb, what colour on usb cable to which usb connections on pcb.
    Thanks
