Peripherals Mechanical Keyboards
Discussion in 'Hardware' started by Raptor77, 27 Dec 2011.
  1. mark1903
    mark1903 Minimodder
    27 May 2011
    @ Spreadie, I have checked the <, and >. and all the <, keys I have are the wrong profile :( but I have looked out the V and >. keys for you.
  2. David
    7 Apr 2009
    Mark, I've had a look through my white on black keys and I think you already have everything I have.
    Posting my collection of mods and novelty keys:
    The Japan mod is on hold for Margo and one of the red control keys is going to Lenny.
    I'm looking to swap a black on blue Alt for a white on blue, if anyone is interested.
    I still need to sort out some og the lighter shaded 1x1 keys.
  3. el2k
    el2k Modder
    18 Jan 2010
    I may need some of those bad boys, will PM after football training!
    Sent from my iPhone using Tapatalk
  4. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Damn Spreadie I think you got the best bag. Have still to see what MSHunter and adrock got, so still over 1000 caps unaccounted for. :)
  5. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Guys, what do you think about WASD keycaps?
    I already asked about it on GH, but wanted to know your opinion too.
    What I'm looking for is retro beige ISO set for my QFR.
    WASD has their grey caps, which would similar to beige old caps.
    Looking for old keyboards with ISO UK set sounds like a nightmare, so thought I would buy WASD set.
    What do you think about them? Are they good quality? Better or worse than original CM QFR caps?
  6. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    They are maybe on a par with oem caps. They are quite thin. I have a couple of sets of alphas from them. They are alright. I just don't much like the OEM profile.
  7. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    Looking to get a mini travel keyboard (KBT Pure) but need it to be a silent MOD.
    Would brown or red switches be better?
    plus rubber ring or pads? Does any one have experience with this?
    Mow much quieter is it?
    Would REDs register with a rubber ring at the bottom?
    Since my other keyboards are brown should probable stick with brown right?
  8. David
    7 Apr 2009
    I have o rings on my reds - they're great.
    No experience of anything else other than a short time with blues.
  9. Krikkit
    21 Jan 2003
    Surely reds will be quietest of all? Being tactile, browns do have an innate noise to them, although it's extremely quiet.
  10. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Reds and blacks are virtually silent if you don't bottom out; blues are surprisingly quiet this way too... the clicks really aren't loud.
    I mean it, if I had to choose a switch right now I couldn't ... there are pros and cons to all the switches. I tried browns the other day and I found them a lot lighter than I expected; I think I prefer more resistance which is why I quite like blacks, but I love the very pronounced tactility of the blues with their click.
  11. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    Where did you get your O rings?
  12. David
    7 Apr 2009
    I got them from Shirty, but you can get them from WASD's feebay store.
    clicky
  13. David
    7 Apr 2009
    I quite fancy trying out MX clears.
    Pics of my other caps, not including my partial alpha set:
    ttfn
  14. phinix
    28 Apr 2006
    What is OEM profile? What is the difference between OEM and Cherry? Are these only two profiles available? Why don't you like OEM profiles?
  15. GeorgeK
    18 Sep 2010
    Cherry profile are lower profile - OEM are higher profile. I'll try to find a diagram.
  16. Shirty
    18 Apr 1982
    The only safe bet is to buy four or five keyboards ;)
    If you like heavy keypresses try a board full of super blacks - you'll have finger muscles like nobody's business if you can learn to type on those!!
    NOTE: You will have to do some modding to achieve this.
  17. mark1903
    mark1903 Minimodder
    27 May 2011
    There is also SP profile which is very similar to cherry but (I think) there is a slight difference in the bottom row.
    SP caps profile diagrams can be found here
    The normal profile is from the DCS family.
  18. Margo Baggins
    28 May 2010
    this pic sort of shows it. I think choosing the F cap for the pictures was a bit of a mistake, as cherry's have scoops not nipples (saucy). But you can kind of get the gist - OEM profile is alot taller, especially at the front. Overall - it's just a preference thing, if you aren't used to any other profile than OEM, you won't experience any problem with it.
    SP profile is very similar to cherry. It's just annoying that SP don't really make caps with square corners that are the same profile-ish as cherry, they all have rounded corners.
  19. phinix
    28 Apr 2006
    Hmm.. when I started to use QFR I noticed how high are those caps.
    So I'm guessing OEM will be the same size/height?
    What difference in height is there between OEM and cherry?
  20. GeorgeK
    18 Sep 2010
    The QFR caps are OEM caps so they'll be identical. Cherry caps are about 75% of the height - if you look at the third pic here you'll see that for the Esc row the caps are 9-10mm instead of 12-13 mm (can't link to the pic for some reason...)
    YEHBABY likes this.
