Development menu program how to make one?
Discussion in 'Software' started by xwerxes, 7 Oct 2004.
  1. xwerxes
    xwerxes What's a Dremel?
    12 Jun 2003
    I was programming a program to work like a menu you got links/buttons to click that will the run programs/games/commands. The links should be written like a command you type in the windows run prompt
    ex. c:\windows\explorer.exe c:\windows
    but I dont know how :blush:
    I'm using borland c++ 6 builder
    [edit] I tried googling but only found junk so thats why I turn to the friendly people at bit-tech :D
  2. ManStrike
    ManStrike What's a Dremel?
    29 Jan 2002
    don't understand
    are you trying to input the text or run it or what?
  3. xwerxes
    12 Jun 2003
    both. but typing the text isnt the problem I'll joust type it in a box but then the problem is how to run what I type in that box ex. I type "c:\windows\explorer.exe c:\windows" in the box and then I want to run it (run explorer with the extra command c:\windows) the problem is how to run it and it has to be in windows programming
    [edit]what command to use
  4. Hargle
    Hargle What's a Dremel?
    13 Oct 2001
  5. xwerxes
    12 Jun 2003
    Thanks it worked perfectly :thumb: I knew I kould trust the guys at bit-tech :D
