mobo - straight swap.
Discussion in 'Hardware' started by mushky, 13 Aug 2004.
  1. mushky
    mushky gimme snails
    24 Mar 2003
    Should I be able to swap my motherboard out without messing windows up?
    I'm oing from an NF7-S v2 to a DFI infinity, so the chipset is the same. I'm not worried about having to reinstall LAN drivers or anything like that, as long as I'm prepared for it.
    would a repair install of XP be enough if the straight swap doesnt work? I dont want to do a full format + install.
  2. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    I did that (change mobos) before, when I started windows it forced me to reactivate windows for some reason, and i used up my product keys 5 times, so i had to phone up and argue with microsoft that I was just changing the mobo. I won of course :D
    Me: 1
    Microsoft: 0
    :rock:
  3. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    im about to change to a NF7-S lol, so u think it should be ok though?!
  4. mushky
    mushky gimme snails
    24 Mar 2003
    i think so, i'm just gonna do it. I cant see how it can go too wrong with 2 mobos with the same chipset.
  5. biff
    biff What's a Dremel?
    8 Jan 2004
    I went from a nforce2 to a kt400 mobo with no probs... windows took care of itself. I was planing on a fresh install but all is well and that was 3 months a go.
  6. lcdguy
    lcdguy Minimodder
    25 May 2004
    Murphys Law :)
  7. mushky
    mushky gimme snails
    24 Mar 2003
    i still owe that guy a slap or two.
    :D
  8. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    It'll all work fine, I still have an install of Windows that I made on an 8RDA+, then installed an NF7-S on, and then a DFI Lanparty into...and then when I got this new NF7-S I used that install for a bit on it too. The most you'll get is a load of "Found New Hardware" prompts and have to do a lot of clicking, on the 8RDA -> NF7-S changeover I didn't even have to do that. It works fine ;)
  9. mushky
    mushky gimme snails
    24 Mar 2003
    Thanks Kam :)
    It seems silly to have a dfi infiinity, 2x256 BH-5 and a XP2500-M sitting in a box here, while im using my 2nd choice parts to play doom3 on .... :p
    (waiting for me to get round to cleaning + lapping all my WC stuff).
    I might as well have a quick swap around while I pluck up the motivation to service the watercooling gear.
  10. Fronzel
    Fronzel What's a Dremel?
    9 Mar 2002
    I don't recomend it, but normally if you have the same chipset, it isn't really a problem. I personally use a motherboard swap as a good time to clean out all the bit rot and worthless data I save for some reason that made sense six months ago. Now I wonder why I have a flash of a baby singing "I pooped my pants"
    I've done this several times. The majority of the arguements goes like this:
    Microsoft: Why are you reactivating?
    Fronzel: I changed the motherboard.
    Microsoft: Is this copy of XP used on another computer?
    Fronzel: Nope.
    Microsoft: OK! Your new code is...
