Case Mod - In Progress MONO -( COMPLETED )-
Discussion in 'Project Logs' started by BERNARDO, 11 Sep 2016.
  1. BERNARDO
    BERNARDO Bernarndo mod chop
    1 May 2014
    hi guys , im jesse from bernardo modchop facebook page https://www.facebook.com/popoy.rAMDom/.
    Im making a worklog to this beautiful case from fractal design, The define nano s - white
    thanks
  2. BERNARDO
    1 May 2014
  3. BERNARDO
    1 May 2014
    cutting out the back panel , planning a btx setup
  4. jojoharalds
    jojoharalds Minimodder
    30 Apr 2014
    Your first post must show work in progress, not just a heap of parts and some rough sketches. If you have no physical modding to show, wait until you do or start your log in the 'Modding' forum. In this case, once you do start physical work, request that the project be moved to the project log forum by contacting a mod or emailing modding@bit-tech.net. The general idea here is to maintain the high quality content we’re all used to.
  5. BERNARDO
    1 May 2014
    now the motherboard tray
  6. BERNARDO
    1 May 2014
    revit it again and heres how it look for now
  7. BERNARDO
    1 May 2014
    heres the top panel cut , too see view of the gpu
  8. BERNARDO
    1 May 2014
    cutting the front panel
  9. BERNARDO
    1 May 2014
    i have some deepcool 120mm fans , i like their fan blade looks good and paint them, perfect its a clear case fan its easy to paint what ever color you want
  10. BERNARDO
    1 May 2014
    night time painting , also have 140mm deepcool clear fans here for my front panel
  11. BERNARDO
    1 May 2014
    painting my 780 poseidon gpu
  12. BERNARDO
    1 May 2014
    adding some accent so will not look so flat
    here we go
  13. BERNARDO
    1 May 2014
    ok featuring the asrock z170m-itx/ac motherboard , will paint the heatsink over there so it will look all black on the motherboard
  14. BERNARDO
    1 May 2014
    next introducing the team dark 4 t-force
  15. BERNARDO
    1 May 2014
    the kelvin s24 AIO cooler
    its unique you change the fittings , and its easy, with a standard g1/4 threads, dismantling it changing it with barrow acrylic fittings and acrylic tubes
  16. BERNARDO
    1 May 2014
    i will be using this stuffs
  17. BERNARDO
    1 May 2014
  18. BERNARDO
    1 May 2014
    making a IO cover , asrock style
    and heres the output, mono on top
  19. BERNARDO
    1 May 2014
    acrylic back panel some holes in it and i use clear acrylic to see all the parts inside the case
  20. BERNARDO
    1 May 2014
    installing acrylic clear panels with allen bolts
