Electronics More Eagle questions...
Discussion in 'Modding' started by H2O-G33K, 24 May 2006.
  1. H2O-G33K
    H2O-G33K What's a Dremel?
    25 Jan 2003
    Does anyone know how to tell the Eagle PCB layout to put some components on the back of a board? I want to produce a two-sided prototype but after much googling and poking Eagle, I'm still stumped :(
  2. nleahcim
    nleahcim What's a Dremel?
    22 Apr 2003
    Your question would be better suited to the Eagle community, but oh well. You want the mirror command. edit -> mirror or use the button underneath the move crosshairs.
  3. fat-tony
    fat-tony What's a Dremel?
    26 Mar 2006
    You're putting actual components on the back side of the board? I assume this must be SMT components?
  4. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    unless is is SMT components, keep components on one side, and put tracks on both sides :)
  5. H2O-G33K
    25 Jan 2003
    They are indeed SMT.. and cheers, the mirror command sorted it.
  6. LexT
    LexT What's a Dremel?
    8 Jun 2006
    Try using Diptrace package, realatively simple yet full of features. And they have a free version on website.
