Motors mot question
Discussion in 'General' started by pranks7er, 4 Aug 2008.
  1. pranks7er
    pranks7er mange tout
    25 Dec 2002
    my car is up for mot next week but i have broken one my alloys and there no way i could afford get it fixed or replaced in time, will the car pass with a spare tyre on its not the space saver tyre but proper full size tyre
  2. CobraMods
    CobraMods Gettin there slowly
    28 Mar 2008
    as long as it is a full sized spare the same size and rating as the one on the opposite side of the same axle it will pass. make sure its not a directional tyre on it cause it would even fail if it was mounted in the wrong direction.
  3. peteone
    peteone Minimodder
    5 Jun 2002
    Would you not have to have the spare in the boot for it to pass too?
  4. alextwo
    alextwo <a href="http://forums.bit-tech.net/showpost.php?p
    29 May 2003
    Nope
  5. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    na, they took that out a couple of years ago
    that's how lotus gets way with having no space for a spare:)
  6. Krikkit
    21 Jan 2003
    And how BMW get away with run-flats. :)
  7. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    And also how cars that have the LPG Conversion and a can of spray in the tyre repair foam get away with it.
    Same as reverse lights not working, they also are not a requirement of the MOT :)
  8. peteone
    peteone Minimodder
    5 Jun 2002
    Yeah come to think of it theres a few motors that dont come with spares.
  9. peteone
    peteone Minimodder
    5 Jun 2002
    Wonder why that is??
  10. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    I'm not certain, but my understanding is that you don't have to have a spare, but if you do it has to be up to standard.
    As such use the spare in place of the broken alloy, which should be left at home.
  11. CobraMods
    28 Mar 2008
    if i remember right 1 reverse light had to work, also be careful on your indicators, the coloring flakes off the bulbs over time and if the tester wants to nit pick they can fail them if they are not a decent shade of amber.
  12. kennethsross
    kennethsross What's a Dremel?
    29 Jul 2008
    I watch most of my MoT's. Never once seen the spare being checked.
  13. pranks7er
    25 Dec 2002
    jsut checked my spare is slightly smaller in width they have be the same size
    so gonna borrow alloys of my bros car jsut for the test
