Windows Mouse cursor unresponsive
Discussion in 'Software' started by Fule, 8 Oct 2010.
  1. Fule
    Fule The letter D
    8 Feb 2010
    I upgraded my Catalyst drivers to 10.9 through the Steam context menu the other day and a bizzare issue has popped up
    I run 2 24" screens with UltraMon, when I move my mouse off screen to the right of the right-hand screen, the cursor won't come back. Ctrl-Alt-Del brings it back to life and I can move it back onto either screen, but the only option I have is to log off and log on again.
    I've rolled back the drivers with no joy. Any ideas chaps?
  2. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
  3. SouperAndy
    SouperAndy To Bumble or not to Bumble?
    16 Feb 2009
    I assume UltraMon hooks into some pretty low level graphics driver functions to work. Have you tried reinstalling UltraMon?
    Alternatively, have you confirmed that the ATI and Windows screen properties are aligned? Maybe they are 'confusing' each other?
    Cheers,
    SouperAndy :worried:
  4. Fule
    Fule The letter D
    8 Feb 2010
    Appreciate the suggestions gents, neither have done the business though :(
  5. SouperAndy
    16 Feb 2009
    Sorry for the late reply.
    I'm a bit stuck then TBH. I've never used UltraMon, so can't be specific.
    Can you try disconnecting the second monitor and rebooting into Windows? This may 'reset' the display configuration.
    Confirm that the mouse cursor operates correctly with a single screen.
    If it does, shutdown and reconnect the second monitor and test.
    Cheers,
