Windows MSN 6 - System Requirements?
Discussion in 'Software' started by Dorza, 23 Jun 2003.
  1. Dorza
    Dorza What's a Dremel?
    8 Dec 2002
    Is it me or do these requierments seem a bit much for the type of program MSN is:
    Minimum System Requirements:
    Multimedia PC with 233MHz processor or faster (500MHz recommended)
    Minimum 64MB of RAM (128MB recommended)
    Up to 50MB of hard disk space needed to install — after install, up to 15MB may be needed
    256-color VGA or higher resolution graphics card (SVGA recommended)
    Minimum 800x600 screen resolution
    Y does it require what i think to be such high requirements for this prog?
  2. Reflex
    Reflex What's a Dremel?
    8 Dec 2002
    prolly cos its so badly made? it is of course ms :hehe:
  3. Kargin
    Kargin Overdose . . .
    18 Sep 2002
    You might notice a similarity between those requirements and the requirements for Windows XP, the most demanding Microsoft OS currently capable of using MSN, minus the drive space one of course :p
  4. maki43
    maki43 I can touch my toes 1,2,3
    8 Nov 2002
    got it running on a p70 now, runs fine :thumb:
  5. loply
    loply What's a Dremel?
    26 Dec 2002
    You need an 800x600 monitor cus the chat windows dont fit on a 640x480 by default lol (no ****ting! one of the damn things fills an 800x600!)
