Modding muahha seth plans an other mouse mod
Discussion in 'Modding' started by Seth, 27 Aug 2002.
  1. Seth
    Seth What's a Dremel?
    14 Mar 2002
    I previously did a wireless optical logitech mouse the nice black one with a blue light.
    well now I plan on doing the dual optical version with blue lights muhahha should look sweet.
    oh and if your thinking of buying the dual optical go for it the mouse rocks.
  2. Phire
    Phire Performance-PCs.com
    11 Jan 2002
    muwahahah I have 8000mcd blue-green leds in the mail, we'll see who does it first! :D
  3. Seth
    14 Mar 2002
    blast you!
    I would really like to see what these leds look like because they have a lot higher mcd rating then the blues.
    what site did you get them off of?
    I was thinking of getting some from here.
    they sell blue and aqua also.. you think the blue green is aqua?
    http://www.superbrightleds.com/leds.htm
  4. Phire
    11 Jan 2002
    this guy I got them from got 20 as a free sample from some company....I will try squeak it out of him :)
  5. synctec
    synctec What's a Dremel?
    12 Mar 2002
    I've got a microsoft Intelli mouse optical, do you think i can change it led to blue?
  6. Seth
    14 Mar 2002
    can you punk me 2 if possible from your friend? I will pay you for the shipping yes no?
    and yes you can put a blue led inside a intelli mouse explorer but you will not see it as blue the bottom plastic is red so it will change the color (look purple?) never seen one done, but if you do it make sure you have a really bright blue led one with a small viewing angle it is more direct light.. or maybe not but a higher rated mcd blue led will work well for you.
    and to get that mouse appart you have to move the little pads on the botton the screws are underneath them.
    good luck
  7. MaximaMan2000
    MaximaMan2000 What's a Dremel?
    6 Jun 2002
    I know a plase were you can get 18000mcd green 5mm and 11000mcd green 3mm
  8. Pflumingo
    Pflumingo givem the bird.
    17 Jul 2002
    Maxima, Wanna give us a clue or just tease us with that statement??? :eyebrow:
  9. Linkitch
    Linkitch What's a Dremel?
    11 May 2002
    Are we talking about changing LED's in a Dual Optical mouse here ??
    If we are check this out.
    Under Guides
  10. Seth
    14 Mar 2002
    blast someone beat me too it, no fair
  11. j`w0n
    j`w0n What's a Dremel?
    17 Jul 2002
    Um would a 9000 mcd aqua LED with an 18º viewing angle be okay for changing the main red led on the Intellemouse?
  12. Phire
    11 Jan 2002
    I would say yes, although I dont know how aqua does with the tracking, but considering the viewing angle and mcd rating, try it....!
  13. MaximaMan2000
    6 Jun 2002
    at Mouser Electronics the 5mm are 604-L7113VGC/H and the 3mm are 604-L7104VGC/H. Those are the item numbers
  14. n0fear
    n0fear What's a Dremel?
    26 Aug 2002
    Just my personal opinion but the logitech dual optical sucks for anything other than desktop usage... ie; dont try using it for gaming it's crap
  15. Seth
    14 Mar 2002
    are you kidding me!
    you must be smoking some really bad stuff.
    I play a lot better in halflife with the dual optical then I do with my microshaft intelli explorer.
  16. n0fear
    26 Aug 2002
    it was terrible, i tried it for a week... i didnt get used to it at all, and it was impossible to kill anyone in any game
  17. Buzzard
    Buzzard What's a Dremel?
    4 Feb 2002
    Optical still too slow for gaming :-/
    If u're not fast with the mouse it might be ok though..
    ball > all
  18. n0fear
    26 Aug 2002
    There was something wrong with the tracking on that mouse... it kept getting confused. I tried generic windows drivers (xp pro), and the logitech (out of box, then updated) and it was still teh same. i also tried loads of "fixes" for it, but nothing worked. Good ol' ball mouse works great though!
