Electronics Multipurpose PC-Board
Discussion in 'Modding' started by Cerenkov, 9 Jan 2007.
  1. Cerenkov
    Cerenkov What's a Dremel?
    13 Dec 2004
    It looks just like that. I'm trying to figure out how to do 2-3 arrays of 5 LEDs each. I know the math of wiring them up, I have the components, but I can't quite crunch my brain around how to align them on this. Any and all help or mocking is appreciated.
  2. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    just take a knife and slice/break the traces where you dont need them connected.
  3. Cerenkov
    13 Dec 2004
    That works for me. But I mean, if I need one track connected to another, do i just bridge the gap with solder or wire or what?
  4. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    Yes.
  5. Cerenkov
    13 Dec 2004
    Alright then. Just wanted to be suuure ^^. Draping solder across two joints like that won't weaken it right?
  6. mattthegamer463
    26 Nov 2004
    It will be fine as long as you put a sizable amount of solder on it.
  7. Cerenkov
    13 Dec 2004
    One more question. Where would be the best place there to hook up the 5v and 0v wire?
  8. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    generally the top row and bottom row
  9. Cerenkov
    13 Dec 2004
    Guess i should've just gotten over my fear of screwing up in the first place and played around. Today I finally got my medicine and I'm able to think without fever and with clarity.. this is much easier than I thought X)
  10. DarkInferno
    DarkInferno Minimodder
    28 Nov 2004
    if it is the same as that board I'd hook the power lines to the to rails in the center
    But just have a play... if you break it, which is unlikely, its only a few quid for a new one :p
  11. Snood
    Snood What's a Dremel?
    27 Feb 2003
    i recomend making links with wire as if it were a component rather than bridges made of solder. it's just neater, more reliable and easier for me,, it can sometimes be dificult to get a big blob of solder to go where you want it.
  12. Cerenkov
    13 Dec 2004
    Alright. Haven't started yet, I'll strip some 24 AWG and get crackin
  13. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I try to design the board so I can fit PCB-mount connectors for inputs and outputs. The screw ones shown are 0.2" pitch, fan-connector headers are 0.1" pitch.
    Picture also shows some wire links as Snood advises. For breaking the tracks, a hand-held 1/4"-ish drill-bit makes a quick neat job - you can fix one in a cork for a permanent tool.
