Small Form Factor My little Shuttle.......
Discussion in 'Hardware' started by [twig]clown, 1 Mar 2004.
  1. [twig]clown
    [twig]clown What's a Dremel?
    1 Jan 2003
    I got some pictures of it, and finally got them hosted, so I thought I would let you guys have a look.
    Still stuff to be done to it as you can probably tell, but isnt there always.
    Anyways, enjoy! Lemme know what ya think.....
    Front:
    Side:
    Side Window (With Fan grill,working on it):
    Top Window:
    My Stealth Job:
    Thanks
    -cLoWn
  2. phaSe
    phaSe What's a Dremel?
    4 Jul 2002
    looks cool! are there any lights inside? or is that on the todo?
    :thumb:
    RoB
  3. [twig]clown
    1 Jan 2003
    The rear 80mm has been replaced with an 80mm white LED coolermaster. The window pic which is illuminated has one of the two 6" white cathodes above it, the other was along the front, but now has been moved to up the side to illuminate the freshly installed graphics card.
    -cLoWn
    Edit: Both the windows are tinted with an extra dark tint (theres a story....), so the cathodes and LED fan dont seem there usual brightness (this is because I have enough light in my room [if you notice what the shuttle is perched on], and also looks deadly cool when off).
  4. phaSe
    4 Jul 2002
    cool. :thumb: just wondering :lol:
    RoB
  5. [twig]clown
    1 Jan 2003
    Damn o_O that was fast!
  6. phaSe
    4 Jul 2002
    well its a tough call....bit or revision....bit or revision..... :D
    RoB
  7. ajack
    ajack rox
    17 Apr 2003
    Very nice job there...reminds me that I need to get mine done at some point :)
  8. [twig]clown
    1 Jan 2003
    :lol: lol :lol: Gd luck in what ever your revising :thumb:
  9. richman
    richman What's a Dremel?
    17 Sep 2003
    :jawdrop: :jawdrop: :jawdrop: That is nice, is this pc your main rig or do you use it for lans or what iam thinking of getting a shuttle but not sure, the other option is for me to build a full sized system
    Richman
  10. [twig]clown
    1 Jan 2003
    Run quite a few systems in my house. But this shuttle and computer its standing on in the pics are the only ones which are mine. The shuttle isnt my primary machine, it is used for gaming and taking to LANs. But it could easily be my main computer, it has everything I need to be. I did take my larger computer to LANs, but soon sought after something smaller and lighter. The shuttle is perfect, put in its bag, that on one shoulder, ruck sack with mouse, k/b, few cables, and one of my tft's under my arm.... its definatly the way to LAN!
    Thanks for the kind words guys! :)
    -cLoWn
  11. Xgamer
    Xgamer What's a Dremel?
    29 Oct 2003
    I like the fan grills where did u getem? :thumb:
  12. [twig]clown
    1 Jan 2003
    Fan grill is not bought. Concept by me, drawn by a friend, cut by Kong (what a guy... :rock: ). So sorry, you cant buy 'em.
    -cLoWn
  13. Tommy D
    Tommy D What's a Dremel?
    3 Mar 2004
    Looks awesome mate, good job! :thumb:
  14. door5678
    door5678 What's a Dremel?
    2 Mar 2004
    sweet
