I havent done a lot but i felt the need for a rheobus since my delta screamer is driving me nuts. Also i thought i could stealth my floppy which took me about 2 hours to do and its still not finished cos i need to paint the button silver. And lastly i gave my case a good cable tidying up. lets get to the piccies shall we rheobus stealthed floppy with activity light off stealthed floppy with activity light on cable tidying cable tidying closer i know the floppy needs a lot more work like some optical fibre thru that hole so the light can be reflected better. Considering it took me only two hours, a dremel, needle files and some head scratching.
ok here are the links sorry about my stupidity with message boards here is the link http://www.geocities.com/gerti008/
I dont think you can use geocitys to directly picture you stuff maby if you give links to the page ? Yup i just went to the page and your rehobus looks sweet are they those UV lcds ?
if you want to email the pictures to me, I can host them for you... if you want to continue to use geocities, rename the files to .txt and you can directly link to them
dude, send them to my email and ill upload them to my web space for you should find it in my profile ;P
here we go again cable tidying 1 cable tidying 2 floppy light off floppy light on rheobus Thank you Digital Fodder
thats alright m8 for the moment considering it only took me about 2 hours to do it. I admit it needs a bit mor filing but it should be ok in the end.:dude:
* Ug faints I think you took the more difficult of the two of options. I would aply silver laquer or something similar to the floppy front. Ug
