My project called BANSHEE !!!!
Discussion in 'Project Logs' started by mightynimrod, 19 Apr 2005.
  1. mightynimrod
    mightynimrod What's a Dremel?
    7 Jan 2004
    Well, it's time for me to input something into the modding forum.
    I've been collecting some bits for a new project of mine and now i can finally start on it.
    The donor case in question is a Lian Li PC70 which i got from my good friend Legion.
    The Spec of my setup will be (for the time being anyway)
    COMPONENTS
    DFI Ultra-D
    A64 3000 0448 SPAW @ 2700 on air
    1GB G.Skill LA PC4800
    ATi X850XT-PE
    1x80GB Maxtor SATA
    1x300GB Maxtor 10
    WATER COMPONENTS
    Cathars G4 Storm CPU block
    Dangerden Maze 4 Acetal 2005 block
    Aqua-extreme AQX50Z Pump
    Dangerden Fillport
    Thermochill 120.3 Radiator
    Panaflow 120x38mm fans x3
    Tygon R3603 and R1000 tubing
    Here's where it all starts!!!!
    Right 1st things 1st.....time to cut the holes for my Thermochill 120.3 radiator and dangerden fillport....yes - you've guessed it - i'm watercooling in this little beauty.
    And one more with the rear fan guards cut out and removed to reduce noise and aid air flow.
    More to come
  2. mightynimrod
    7 Jan 2004
    Next thing to do was to braid the cables from the switches to the motherboard and the fan controller
    Then cut the hole for the pump in the hard drive caddy
    While the braiding was out i did the pump before installing it
  3. mightynimrod
    7 Jan 2004
    Here's the pump installed into the cage
    And fitted into the case.
    I then put the radiator in.
    The config for the fans e.t.c on the raddy is:
    Panaflo's in a pull config out of the case mounted on some gutted cheapy 120x25mm fans to eliminate the dead spot and create more suction through the raddy.
    That lot's then fitted to the Thermochill 120.3
  4. mightynimrod
    7 Jan 2004
    Well, here's the top of the case so far.
    And here with some tubing starting to make it's way into the setup.
    Here's one of the front of the raddy with the fillport tubing routed down to the "T" line just before the pump inlet.
  5. mightynimrod
    7 Jan 2004
    Here's an earlier pic i took before i stripped it and cut the fillport hole (i'd done the fan holes before) also with the Lian Li stealth bezels and fan controllers - not to mention the Lian Li window panel :D
    Kind of gives you an idea of what it'll look like from the exterior when it's finished.
    Here's one of the Dangerden Maze 4 Acetal GPU block next to my MX1000 - it's mahoosive :D
  6. mightynimrod
    7 Jan 2004
    Here she is leak testing.....this week folks and it'll be hardware in and getting chilly on yer ass.
  7. mightynimrod
    7 Jan 2004
    Right, emptied the whole lot and re-routed the tubing, wasnt 100% happy with it before.
    Here's the mobo with CPU ready to mount the G4 on it.
    Here's the G4 mounted (ooo-eerrrr too much love for ya hardware) along with the X850XT-PE and Maze 4 acetal.
  8. mightynimrod
    7 Jan 2004
    And the last one for tonight - here we are with it up and running :D
    cpu temps are 38 degrees idle with no noise at all from the 3 panaflos on 7v.
    According to ATitool the GPU is only 35 degrees at stock speeds on idle :eek:
    Pump is a bit buzzy but i reckon a good wad of foam will sort that out to stop vibrations carrying through case to make it silent as if i lift the HDD cage out of its position it's silent.
    So still lots to do to make it 100% but the main thing is the hardware is in and running....yipeeeeee
  9. Buzku
    Buzku What's a Dremel?
    7 May 2004
    Looks promising.
  10. mightynimrod
    7 Jan 2004
    Cheers matey - 1st 3D mark run
    03 and 05 to follow
    Not bad for 2700mhz and 600/600 from the XT-PE
  11. mightynimrod
    7 Jan 2004
    Here's my 1st 03 score
    And my 05 score
  12. kickarse
    kickarse What's a Dremel?
    6 Oct 2004
    are you a procooling nut?
    GJ
  13. mightynimrod
    7 Jan 2004
    Just thought i'd share with you some of the mods that ive done on my case to enable me to run high end watercooling.
    Ive had Prommies before - but prefer the ease and silence of water.
  14. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Very nice work, another clean Lian-Li :D
  15. devenfore
    devenfore LANCandy
    8 Jul 2003
    Is that MX1000 a LOT shinier then normal???
  16. gatecrasher1986
    gatecrasher1986 What's a Dremel?
    6 Nov 2004
    Very nice just sweet and simple.
    Are you not woried about EMI from the pump affecting your hdd's after a long exposed period of time?
    Or is the pump you are using good at not giving out EMI?
  17. MeanMachine
    MeanMachine What's a Dremel?
    7 Apr 2005
    Nice and clean mod! :thumb:
    where can you buy those nice 120mm fan grills ?? :rolleyes:
  18. mightynimrod
    7 Jan 2004
    I got them from the states at the same time as i got my pump.
  19. leviathan18
    leviathan18 What's a Dremel?
    17 Mar 2005
    why your mx1000 is so shinny mine is a kind of blue... :sigh: i like yours :rock:
  20. j.rhy@n
    j.rhy@n What's a Dremel?
    10 Feb 2005
    Use Image Shack for hosting your photos...
    Cant see them any more..
