Modding Need a way to decrease case weight(generic)
Discussion in 'Modding' started by morishani, 17 Dec 2004.
  1. morishani
    morishani What's a Dremel?
    29 May 2004
    My friends case is very old and very FAT, and we need a way to decrease he's weight :\
    b.t.w,
    No, we dont have any money, we just have to figure the way :)
    10q
  2. Langer
    Langer Jesse Lang
    24 Jan 2004
    Do you have any pics?
    what kind of case is it?
    what does he have in the case?
    is the computer still plugged in? Becuase that'll make it hard to move, giving the inpression that it is actualy really heavy.
  3. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    Really the only way to decrease weight is to simply take things out (although there's not much you can take out and make it functional unless he's thrown a microwave or something in there... :worried: ), or to replace the case with lighter materials. If its that old, it's probly just one big steel case, like an old Gateway I took apart, damned thing was manufactured like a tank. I would suggest just buying a new case.
  4. morishani
    29 May 2004
    everything is out of the case :hehe: .
    it's still heavy, even only the doors are very heavy :\
    any :idea: :dremel:
  5. infered101
    infered101 Minimodder
    30 Oct 2004
    If the metal is that hard just cut it out and use wood or winodw the hole thing. Just screw some plexi glass to the frame that will take the weight from the side panels donw.
  6. Zephyr
    1 Oct 2004
    If you really really want to decrease weight and spend next to nothing, just take off everything you can from the case, leaving just a frame holding your parts, and cover it in plastic wrap. Cheap, easy, and it works.
    :hehe:
  7. morishani
    29 May 2004
    Yeah, thought about the window thing, he will lose 20%-30% of all weight.
    but , what with the other window? :\
    may-b ill give u a picture tommorow so u can c the #$@! case :)
  8. Zephyr
    1 Oct 2004
    For the price of acrylic, and the time it would take to cut all that steel, you may be better off buying a new case. Although, I know I would enjoy modding it more than buying it. :dremel:
  9. fuksis
    fuksis What's a Dremel?
    16 Dec 2004
    Lol well one of the solutions is just like they did in old sports cars.
    Drill holes where you can ;)
    You know simple math.
    Les metal lest weight ;)
  10. Gascan1888
    Gascan1888 What's a Dremel?
    15 Dec 2004
    i would go with this idea, it would be the only one like it EVER :D
  11. slater
    slater Mummy Says Im Special
    18 Apr 2003
    Nothings lighter than a hole ;)
    slater..
    (i used to cut out loads of bits of the motherboard tray to reduce weight, works great!)
  12. crayfish
    crayfish Amazing scenes!
    3 Dec 2002
    Speed holes! :D
  13. fuksis
    16 Dec 2004
    If only there was a way to get CPU speed faster by drilling a speed holes lol. :naughty:
  14. Skylined
    Skylined Minimodder
    3 May 2003
    Get a new case.
    Don't cut an old steel case, they're so nice.
    You cut that and I'll :waah:
    My case is one of those that can be perfectly called TANK. :D
    It's so nice. :)
  15. fuksis
    16 Dec 2004
    LOL I have one like that as well it is like 5 years old lol.
    Well they are heavy but at least you know it is metal not some crap metal replacement.
    Look at some of new crap cases. You pick up a box and it weights about the same as good power supply. You go home and turns out power supply is included with the case inside the box ;) lol.
    For example my case total weight is about 15-20KG.
  16. CREDO
    CREDO What's a Dremel?
    18 Jul 2004
    Another benefit of having a huge old heavy case is their not very attractive for a thief to steal either.
  17. Herbicide
    Herbicide Lurktacular
    27 May 2004
    Fuksis and Slater were right - holes, holes and more holes, just be careful the bottom doesn't fall out when you pick it up. ;)
    - H.
  18. x3x3non
    x3x3non What's a Dremel?
    9 Feb 2004
    Id try to cut as much of the steel away, just leaving the basic frame intact. Then i would replace the cut out steel with some cheap mesh.
  19. Stormtrooper
    Stormtrooper Shh...
    26 Mar 2004
    I would do as x3x3non said, but use some sort of plastic instead of mesh. If the case is built like I think it is, then the frame will be very sturdy.
  20. fuksis
    16 Dec 2004
    He yea may be but know that they will take it any way ;)
    If you don’t want it to be stolen just take it apart and let all cables stick out ;)
    You know cd-room on top hdd sticking from side and stuff.
    If they see that not only they won’t want it they will be a bit sacred of it as well lol.
