Windows Need help with something please.
Discussion in 'Software' started by Vault-Tec, 28 Oct 2018.
  1. Vault-Tec
    30 Aug 2015
    I have a screen saver file here. I am pretty sure it has a flash movie embedded into it, as when I install it it says "you need to install flash". Any way, could some kind soul either teach me how to open the EXE up and pull out the FLV (I assume that is what it is) or do it for me?
    I need the FLV out so I can convert it to a media file that will open in WMP.
    Cheers.
  2. Vault-Tec
    30 Aug 2015
    I think I have it. It was in the Windows folder. Now to try and convert it :D
  3. William Joseph
    William Joseph What's a Dremel?
    28 Nov 2018
    Try to change the format of the screen saver file. May be the "flash" is not installed on your system. So try out some other viewer to run the file.
  4. yupson
    yupson What's a Dremel?
    31 Jan 2018
    You can use an online converter. Just search it online "FLV to WMP file converter". Upload your file and select whatever you need to select and it will automatically convert the file for you and you can download it after.
